Steering Problem, wont turn right - JeepForum.com
post #1 of 3 Old 04-06-2010, 09:14 PM Thread Starter
88Husker
88 YJ, spring flip over, 33 in BFG.
When I'm going slow it will not turn right. At first it was infrequent, now it is all the time. Nothing blocking or rubbing the tire. I was told that I might need an extension for my steering sector(?) When I last drove it home, it turned fine on my curvy road home, but when I slowed down to pull in the drive way it locked up again.
I made the mistake of "helping a buddy" by paying him to lift the jeep. He decided on his own to install a homeade quick disconnect for the sway bar, both are already busted off. I have all ready fixed the drive shaft and muffler since this "buddy" worked on it. I am not an expert on the jeep, but everything on it seems like it is pretty much stock except for the oversize tires and spring flip over for the lift.
I already know the best answer is to not slow down when turning right. I'm also not ready to put it in a NASCAR race.
Thanks.
88Husker is offline
post #2 of 3 Old 04-06-2010, 09:36 PM
MJMPC
You need to fill out your jeep info a little better.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 3 Old 04-07-2010, 07:43 AM Thread Starter
88Husker
Help me out, what else do you need to know? Its pretty much stock, except for the oversize tires and the spring flip over.
I still have a lot to learn about Jeeps, any info would be helpfull.
THANKS
88Husker is offline
blowing ASD crank, wont turn fuel pump wont stop kennymurcia TJ Wrangler Technical Forum 0 12-03-2009 08:22 PM
Steering Problem Help! left turn fine.... start to turn right & there is a delay. opie2l TJ Wrangler Technical Forum 2 06-23-2008 01:00 PM
TJ wont even turn over trav_k1234 TJ Wrangler Technical Forum 8 05-15-2008 07:13 AM
91 Wont turn to the right? nwacarguy YJ Wrangler Technical Forum 4 09-23-2004 06:43 AM
It Wont Turn On Yonni YJ Wrangler Technical Forum 4 04-18-2004 04:46 PM
