Steering gearbox replacement - JeepForum.com
post #1 of 2 Old 04-13-2011, 06:24 PM Thread Starter
mark0530
Anyone having any good pointers for taking gearbox out/in? Its a 95 yj with power steering. I see the hoses and the steering shaft bolt, but they all look kinda hard to get to and turn. I have a clymer manual, but it doesn't go into details. Just says unbolt, catch oil and bolt back in, fill, burp and test.
mark0530 is offline
post #2 of 2 Old 04-13-2011, 06:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I take the hoses loose on the other ends, then pull the box with the hoses attached when possible. Make sure to mark or photograph the lines at the box before loosening or removing. This will allow you to tighten them up prior to bolting the new box in.
When burping, my FSM was very clear about NOT turning the steering. It directed the installer to allow it to idle for quite a few minutes before ever touching the steering wheel. I can't remember offhand, but I think it was at least 5 minutes.
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
