Steering Gearbox Adjustment Writeup - Page 4 - JeepForum.com
post #46 of 96 Old 03-05-2012, 01:20 PM
Awesome
Thanks for the write up! My dad convinced me to do it and with your writeup it was easy.
100 Characters is not enough to have an interesting/relevant signature.
Awesome is offline
post #47 of 96 Old 03-20-2012, 10:21 PM
sdotcarter
Ill be doing this in a few days. Awesome freaking write up. Ill post back with results. Thank you for taking the time to make this thread.
sdotcarter is offline
post #48 of 96 Old 09-15-2012, 09:39 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Thanks again JF!! Hope it works for my problem.
Luck Favours The Prepared
Anticanman is offline
post #49 of 96 Old 09-15-2012, 11:59 AM
sdotcarter
What's your problem anti? I never ended up getting to doing this but I was going to pm you about sloppy stearing.
post #50 of 96 Old 09-15-2012, 12:13 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I think my problem is in the box itself. It's just getting worn out. I'll end up replacing the steering shaft in fear of the mini ujoints going out and the box because it's got something to do with it. There's a dead spot in the steering and I just need to find it. This thread helped with tightening up the steering and making it more responsive but did not eliminate the dead spot. My tie rod ends are good so it's either the box or the pump or both. Tough to tell when nothing is leaking.
I'll just replace everything with upgraded parts and go from there!
post #51 of 96 Old 09-15-2012, 06:24 PM
sdotcarter
What's it mean when your tierod rotates when you turn the stearing? It kinda spins on the knuckle?
post #52 of 96 Old 02-13-2013, 03:49 PM
Jeeppoc
I'm going to replace the gear box.
The adjustment didn't work at all, so I'm gonna replace the box. I'm a noob to steering. Is there anything I need to know?
Also if the problem could be elsewhere, where could I find it?
The slack is 10-2.
Jeeppoc is offline
post #53 of 96 Old 02-13-2013, 04:12 PM
Jeeppoc
Also where can I find an inexpensive one?
Jeeppoc is offline
post #54 of 96 Old 02-13-2013, 08:09 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Do you have a pick and pull type junkyard near you? You can get one off an XJ there.
Also, are you sure that the box is your problem?
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #55 of 96 Old 02-14-2013, 07:32 AM
Jeeppoc
I didn't know an XJ would fit, I'll check around at the junkyard. I'm not 100% certain, but since the adjustment didn't work at all (initially it did help a little, but it didn't last long) my best guess is the gear box.
Jeeppoc is offline
post #56 of 96 Old 02-14-2013, 08:22 AM
Que89YJ
Wait, look at doing the Dodge Durango mod.
http://www.jeepforum.com/forum/f12/w...g-box-1097652/
Que89YJ is offline
post #57 of 96 Old 02-14-2013, 09:42 AM
Jeeppoc
Isn't that for power steering? I have manual steering.
Jeeppoc is offline
post #58 of 96 Old 02-14-2013, 09:54 AM
Gage56
Just did this yesterday and WOW What a difference that made Thanks SO Much OP
Gage56 is offline
post #59 of 96 Old 02-14-2013, 09:59 AM
Que89YJ
Yep, it is hydraulic.
Que89YJ is offline
post #60 of 96 Old 02-14-2013, 02:33 PM
Jeeppoc
That does seem like a nice upgrade, but I'm very limited on time, and I just want to get my Jeep back on the road as quickly and painlessly as possible.
Jeeppoc is offline
Steering gearbox help Dewster196 YJ Wrangler Technical Forum 4 07-23-2009 07:47 AM
steering gearbox adjustment, possible??? anarchyfor2 TJ Wrangler Technical Forum 3 11-10-2008 04:12 PM
Power steering gearbox Piratejonh TJ Wrangler Technical Forum 8 04-21-2008 08:36 PM
Steering gearbox adjustment jaw41272 YJ Wrangler Technical Forum 2 10-16-2007 08:03 AM
Power Steering Gearbox jake7893 TJ Wrangler Technical Forum 0 06-24-2007 07:32 AM
