Quantcast Steering Gearbox Adjustment Writeup - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Steering Gearbox Adjustment Writeup
Old 03-11-2008, 02:33 PM   #16
SonofSam02
It was done on power steering.
I don't know about manual steering.
SonofSam02 is offline   Reply With Quote
Old 03-11-2008, 07:28 PM   #17
Ptr
1992 J-Series Truck
it's the same for no power steering.
i did this to my jeep when i got it. no more huge dead spot in the steering.
Ptr is offline   Reply With Quote
Old 03-11-2008, 09:30 PM   #18
Windsma
Thanks i got off my butt and checked it.
Did the repair job and now I only have about 45* degrees of play. Before there was about 180*degrees play
How far down should the adjustment screw go down. To get the result ^, I had to move it down alot. 2 threads of the locking nut is showing.
I bought my first Jeep yesterday and expected to spend $200-$300 on a new gearbox so THANK YOU SO MUCH!!!!!
There is a rebuild kit for around $75 will that fix it?
[CENTER][SIZE="4"][COLOR="White"]White Jeep Club Member #1981
Burlington, North Carolina[/COLOR]
1990 Wrangler 2.5L bought 3/10/08
70 Camaro RS Dragcar. Watch it fly:
[url]http://www.youtube.com/watch?v=4vL6Ilmdtc4[/url][/SIZE][/CENTER]
Windsma is offline   Reply With Quote
Old 03-11-2008, 09:35 PM   #19
SonofSam02
I don't have the factory service manual infront of me, if that information is even contained in there.
How much it moves depends on if the previous owner moved it/ how far out it is.
There is a point where you should just replace the steering box. Where that is, I honestly don't know.
Mr B, who posted earlier in the thread had to turn his manual box 1 and a half turns.
The rebuild kit, is it just the seals, or does it include all new gears and the like?
Old 03-11-2008, 09:50 PM   #20
Windsma
Also my Lower Steering Column bearing is shot. I need to find a good cheap replacement.
http://i175.photobucket.com/albums/w144/windsma/steeringyj.jpg
^ thats the parts in the kit
heres the quadratec link:
http://www.quadratec.com/products/product_search.php?kw=56112.100&submit=Go%21
Old 03-11-2008, 09:59 PM   #21
SonofSam02
I went and did a little digging in the cj section, since the rebuild kit is for cj's too and i found this
http://www.jeepforum.com/forum/showthread.php?t=293199&highlight=steering+box+reb uild
You may just want to put the 75 towards a already rebuilt one, its halfway there anyway
Old 03-11-2008, 10:18 PM   #22
1 ton yj
Good writeup. Common knowledge to me but I've never seen it here and I'm sure it'll help others. When I was a tech at the Jeep dealer, I was taught to do this to every Jeep prior to aligning it.
This is probably the most detailed thread I've seen on rebuilding the box
http://www.naxja.org/forum/showthread.php?t=20532
1 ton yj is offline   Reply With Quote
Old 03-11-2008, 10:20 PM   #23
Windsma
that thread talks about power steering leaking.
but ill deff. be keeping my eye out for a good used or reman one. Thanks, SOS
Old 03-11-2008, 10:52 PM   #24
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Sounds like you need a new gearbox anyway. You shouldn't still have that much play. Mine was a manual too. You should look into converting to power steering. For about $300 you could buy rebuilt parts, new hoses, a polley, and a new belt. You'll never regret it.
White '94 YJ 2.5L 5 speed, 33" BFGs MTs, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio
Member #94 White Jeep Club
My Jeep
'89 XJ Laredo Bone Stock
KB6NQT
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote
Old 03-11-2008, 11:22 PM   #25
Windsma
Thanks i bought the YJ for my GF and im sure she would love it. ( $300 for junkyard PS kit ? )
Old 04-23-2008, 09:47 AM   #26
thedman
Brilliant! I didn't have to remove the plastic support bar. I have left it a little loose as I am afraid of getting it too tight. But what a difference. Thanks!
thedman is offline   Reply With Quote
Old 07-26-2008, 07:35 PM   #27
Rafikie
Good stuff!!! I just did this to my TJ after reading this write up, took me all of 15mins. Thanks for the write up and thank you JF for a great search engine
97 TJ 4.0, AX15, Back halfing w/ tons and 4?s
Stop by and check us out Western Mass 4x4 or Check us out on Facebook and be sure to stop by and like the NEA4WDC while your there.
Rafikie is offline   Reply With Quote
Old 08-20-2008, 10:19 AM   #28
rip_1986
back to topic please
rip_1986 is offline   Reply With Quote
Old 10-09-2008, 12:20 PM   #29
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Bump. Did this today to fix my loose steering. Ended up doing a full 1/4 turn and she was good to go. I did not need to remove the brake line support bracket thing. A deepwell socket fit right over and rubbed against the bracket.
Also for the allen tool, I used a 4.5mm, it may be 3/16 but mine was awol when I went to get it out of the toolbox.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 10-09-2008, 12:44 PM   #30
SonofSam02
update on mine:
I ended up replacing the steering gear box.
When i adjusted mine, it wouldnt return fully to center after i turned. Actually, i could turn the wheel, take my hand off of it and it would remain there around the corner.
I put the new one in and it returns to center and drive great. There is still a little bit of play but it is somewhere else in my steering.
When i replaced it, i put a transmission cooler inline with the power steering to cool off the power steering. The reason mine failed the first time was that i overheated the fluid on the trail.
Glock Forum
