Steering "Crunch".... - JeepForum.com
post #1 of 4 Old 09-18-2012, 08:17 AM Thread Starter
jaycal3
My Jeep just started making a faint "crunching" sound when I turn - sounds like it is coming from directly under the steering wheel itself in the column. Any idea what it could be? Is there an assembly of some sort to lube up or something that would break off in there? It almost sounds like something is scraping when I turn the wheel.
Thanks in advance,
Jay
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #2 of 4 Old 09-18-2012, 10:10 AM
PA_YJ19
There's a bearing at the top of the steering shaft user the hood, pretty simple to swap out. Sounds like urs has mayb seen better days. Does ur wheel move up and down at all or feel looser than it should?
PA_YJ19 is offline
post #3 of 4 Old 09-18-2012, 10:28 AM Thread Starter
jaycal3
No looseness or movement. Just a crunch. So this bearing is under the hood? My noise is literally just under the steering wheel in the column(or at least I think it is).
Is this what you are referring to?
http://www.jeep4x4center.com/column-bearing-kit-4487696k.html (takes me to the main page when clicked on but to the product when copied and pasted... hmmmm)
KCCO
jaycal3 is offline
post #4 of 4 Old 09-18-2012, 11:31 AM
jokerchief462
http://www.jeepforum.com/forum/f12/l...t-pics-741968/
This is what you are looking for. Did mine the other day about an hour or so and you need a friend to guid the steering shaft on while you reposition the gearbox in the mounts when you are done.
jokerchief462 is offline
WANTED V-BELT Power Steering PULLEY for "89" Wrangler YJ w/2.5 L engine. jeepdiver777 YJ Wrangler Technical Forum 14 01-19-2016 08:27 AM
Steering seems loose and wobbles in bumpy turns after 4" Lift and 33" M/T Tires/Wheel cpd3020 TJ Wrangler Technical Forum 8 10-28-2009 01:18 AM
steering shaft "thing" on firewall not staying in place(pics) chrisjep97 TJ Wrangler Technical Forum 4 06-22-2008 05:56 PM
Local Shop and offroad parts "Over the Knuckle" 1-ton Steering setup Sparty TJ Wrangler Technical Forum 8 03-11-2008 06:00 PM
Feel "clunk" through steering column when you change from Accel to Decel or opposite Mark_ZZ3 YJ Wrangler Technical Forum 5 04-13-2005 08:04 AM
