steering column ? swap? - JeepForum.com
post #1 of 10 Old 09-28-2009, 05:37 PM Thread Starter
yjjason
X-Y-J-Con
yjjason's Avatar
will 96 xj work in my 88yj ? i have tilt with delay wipers ,gm key. what will work? thanks
88yj-94 4.0-ax15-2004 rubicon f/r axles-4.10's-factory air lockers-33"D!ck Cepek Crushers
yjjason is offline
post #2 of 10 Old 09-28-2009, 07:33 PM
om3ga83
not sure about an xj but i got mine out of a fsj (grand waggy) all connections are the same.
om3ga83 is offline
post #3 of 10 Old 09-28-2009, 08:44 PM Thread Starter
yjjason
X-Y-J-Con
yjjason's Avatar
what years? tilt? delay wipes?
thanks
yjjason is offline
post #4 of 10 Old 09-29-2009, 06:02 AM
om3ga83
The whole works it was an 89 wagoneer cruise, delay wipers, tilt...
om3ga83 is offline
post #5 of 10 Old 09-29-2009, 05:35 PM Thread Starter
yjjason
X-Y-J-Con
yjjason's Avatar
thanks for the info
yjjason is offline
post #6 of 10 Old 09-29-2009, 05:42 PM
jbolty
jbolty's Avatar
The whole column is based on a chevy S-10. Direct swap, as far as I know.
jbolty is offline
post #7 of 10 Old 09-29-2009, 06:09 PM Thread Starter
yjjason
X-Y-J-Con
yjjason's Avatar
do you know what years? i'm going to pull-a-part this weekend & would like to know what years & cars to look for!! thanks for the info
yjjason is offline
post #8 of 10 Old 09-29-2009, 11:21 PM
jbolty
jbolty's Avatar
Sorry I don't. I read up on this a couple of years ago when I was thinking about an auto trans to manual swap and I remember that it was supposed to be a direct swap. Mid 80's , as I recall.
jbolty is offline
post #9 of 10 Old 09-30-2009, 03:41 PM
mazyj
i put one a column that i believe was from a cherokee into my '91 YJ. I actually bought it thinking it was also from a YJ but the collapsing steering shaft was much much shorter than mine, so i guess its a Cherokee. Everything worked just fine with two exceptions- i had to cut material off the end of the tube near the bearing at the top of the steering shaft to get it to go into the hole in the YJ firewall and now my wipers are either all the way on or all the way off. Im going to try switching the wiper switch from my old column to the new one and see what happens. As far as i learned they are all GM based columns and are fairly interchangeable, just keep your old switches and wiring harness' and you should be fine. Also make sure you get one with a key or your going to have to change out your ignition cylinder.
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #10 of 10 Old 09-30-2009, 06:15 PM Thread Starter
yjjason
X-Y-J-Con
yjjason's Avatar
the problem with mine(88 yj) is the delay stopped working last week ,now the key cylinder is workinrg part time? so if i can find a swap that will work out of a yard, i think it would be cheaper than replacing parts for mine!!!! thanks for your info!!
yjjason is offline
YJ steering column swap mid 80's S10 Shamrock84 YJ Wrangler Technical Forum 11 07-15-2010 12:23 AM
Steering Column Swap Question Brown Dog YJ Wrangler Technical Forum 8 07-14-2009 08:14 PM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-10-2009 12:20 AM
Steering column swap? brokenwhitejeep YJ Wrangler Technical Forum 0 02-13-2007 04:56 AM
steering column swap Jeep Yj Fred YJ Wrangler Technical Forum 1 08-02-2006 11:01 PM
