??Steering Column shaft with lift?? - JeepForum.com
post #1 of 2 Old 04-02-2013, 07:19 AM Thread Starter
Backcountryasm
I am almost finished with my RC 4" lift on 95 YJ. The PO had installed a cheap plastic spacer 4" body lift and dropped the radiator on the mounts with some fabbed steel links (I plan to replicate the same for the new height). While under the jeep I have noticed the rubber mounts to be in rough shape with splits etc.... I do not want the combo of a 4" body lift and 4" suspension lift so I have ordered a Daystar 1" body mount/lift kit to drop the body height. What will I be looking at steering column wise since I am dropping the body 3"??
Thanks in Advance for all opinions!
Backcountryasm is offline
post #2 of 2 Old 04-02-2013, 08:23 AM
jokerchief462
Well the stock shaft has a collapsing shaft so it depends on weather it is still installed and if so it may just have enough. Or you could look into a new one.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
