steering column lower bearing replacement - JeepForum.com
post #1 of 11 Old 02-17-2008, 12:17 PM Thread Starter
azgurney
Has anyone replaced the lower steering column bearing? Mine is shot. Can it be replaced without removing the steering column. I was thinking if i could remove the shaft to the gearbox I may be able to get to the bearing.
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #2 of 11 Old 02-17-2008, 05:26 PM
Alfons
If this address is working, it will give you a step-by-step write-up to repair your steering column.
Alfons is offline
post #3 of 11 Old 02-17-2008, 06:33 PM Thread Starter
azgurney
I can not get the link to work.
91 Wrangler 4.0 5sp
azgurney is offline
post #4 of 11 Old 02-17-2008, 07:43 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
That was the link I was going to post up. I have that writeup coppied onto my home machine. I will have my brother post it up tomorrow when he is at my house. I am somewhat indesposed at the moment with my son in the hospital.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 11 Old 02-17-2008, 08:25 PM Thread Starter
azgurney
Do not worry about the post Rustywrangler. You have much more important things to take care of at this time. I hope everything goes well for you.
91 Wrangler 4.0 5sp
azgurney is offline
post #6 of 11 Old 02-17-2008, 10:14 PM
philly5eagle
1987 YJ Wrangler
I just replace mine today. Mark the the shaft and the ends it attaches to with a marker so you know where to line it back up to when you reinstall it. I took the bolt at the top of the shaft out and the one at the bottom where it attaches to the steering box. Then, take a big flat head screw driver and put it in the opening at each end of the shaft (a split in the ends of the shaft) and pry them apart as much as possible. Then take a hammer and hit the shaft below the u joint and drive the shaft up(towards the bearing you are going to remove). You have to drive it up as far as it will go. Basically up to the bearing. Each time you have to keep prying that spilt apart and hitting it with a hammer. Just find a spot around the ujoint that you can hit with the hammer to drive it up. Once you get it up to the bearing you will be able to pull the shaft off the bottom where it attaches to the steering box. You may need to push on it a little. Then the fun part of driving the shaft down and off of the other end. May help to have someone pulling down on the shaft while you hammer it. (had my 15 year pulling) Once you have it off you can get to the bearing. Be patient with the hammering etc. It will come off.
Pull the clip (snapring) on the column off. Then pull the cap off (retainer) and then you can pull the bearing and the white thing out(lower bearing adaptor). You will probably have to pry it out with a screwdriver and just work it back and forth. Once it is out put the new bearing in the new white part and put them both on the column. Pry the new retainer on until the holes line up. Put the snapring on and reinstall the shaft.
Not bad. Took me about 45 mins and that was only b/c I was trying to figure out how to get it off. Just be patient. Someone else may have a different way or say this was wrong but it worked for me I just did it about 6 hours ago.
87 yj 4.2 5spd peugeot,(has to go soon), 33" pro comps, 3"bds susp, 2"body, M/C 2100, HEI, and now determined it has a 4.0 head and exhaust
philly5eagle is offline
post #7 of 11 Old 02-18-2008, 05:32 AM
rustywrangler
Already asked em to do it. Not a big deal man. He was gonna be there for the pets anyway.
-Rusty
post #8 of 11 Old 02-22-2008, 06:33 AM
rustywrangler
Here ya go man: http://www.epiccomputer.com/dale/jee...tilt/tilt.html
post #9 of 11 Old 02-22-2008, 04:09 PM Thread Starter
azgurney
Thanks everyone. I have a bearing ordered and will be doing this soon. To rustywrangler, I am glad to here Jacob is home and doing well.
91 Wrangler 4.0 5sp
azgurney is offline
post #10 of 11 Old 02-22-2008, 09:47 PM
Burnerman
Burnerman's Avatar
I replaced mine also. It was pretty stuck on the lower end of the steering colunm. Be sure the steering wheel doesn't get turned when you disconnect the shaft to the gearbox. I used the lock on the wheel and a bungie for extra measure. The bearing uses an O ring to hold it firmly on the lower shaft and the clip holds the race in place. It's tricky trying to pry on it with the brake booster in the way. I skinned a knuckle or 2 or 3.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #11 of 11 Old 03-18-2008, 06:12 PM
Windsma
OMMFG! I am in so much pain after replacing my lower column bearing. It took about 3 hrs. First i tried to take the steering shaft apart. Not happening. I got the old bearing apart and saw that the inner bearing collar was rusted/welded to the shaft , HA , After 1.5 hrs I gave up and decided to remove the entire steering column. A few bolts later it was out. I had to use a chisel and hammer the old bearing off of the shaft. Installed the new bearing set. Reinstalled the column. ( the jeep is not my old 3000gt when it comes to laying on the floor board and working under the dash OUCH! ) Eventually got he shaft to align w/the column. Buttoned everything up and now its easier to steer b/c of less binding in the ujoints and shaft.
White Jeep Club Member #1981
Burlington, North Carolina
1990 Wrangler 2.5L bought 3/10/08
70 Camaro RS Dragcar. Watch it fly:
Windsma is offline
Replacing lower Steering column Bearing on my YJ 3whit YJ Wrangler Technical Forum 38 04-27-2011 10:54 PM
lower steering column bearing Que89YJ YJ Wrangler Technical Forum 6 02-07-2011 02:36 PM
Steering column bearing replacement? 1stJeepyj YJ Wrangler Technical Forum 2 05-05-2007 08:07 AM
how to replace lower steering column bearing? ah77 YJ Wrangler Technical Forum 4 08-04-2006 06:28 PM
Steering Column Lower Bearing idssteve YJ Wrangler Technical Forum 0 11-04-2003 07:33 AM
