steering column lost power - JeepForum.com
post #1 of 5 Old 08-22-2013, 06:01 PM Thread Starter
mturner0111
Jeep won't start won't even crank acts like the steering column has no power any suggestions
mturner0111 is offline
post #2 of 5 Old 08-22-2013, 08:50 PM
gorilla_skater
Does it have tilt steering? Mine has a wiring problem in the steering column. If I have it tilted all the way up, everything works fine. If I tilt it down, weird things happen, like lights come on, won't start, wipers don't work, etc.
gorilla_skater is offline
post #3 of 5 Old 08-23-2013, 12:49 PM
XJ93
Have you checked fuses? Check for power at the harness connector on the column and report back.
XJ93 is offline
post #4 of 5 Old 08-24-2013, 09:53 AM Thread Starter
mturner0111
Found the problem the relay under the hood on the firewall had a melted wire at a fuse link I cut this out an replaced it and everything is working fine again!
post #5 of 5 Old 08-24-2013, 12:21 PM
XJ93
Way to go. Glad it was something relatively simple.
XJ93 is offline
