-   -   steering column lost power (http://www.jeepforum.com/forum/f12/steering-column-lost-power-1565795/)
mturner0111 08-22-2013 05:01 PM
Jeep won't start won't even crank acts like the steering column has no power any suggestions
gorilla_skater 08-22-2013 07:50 PM
Does it have tilt steering? Mine has a wiring problem in the steering column. If I have it tilted all the way up, everything works fine. If I tilt it down, weird things happen, like lights come on, won't start, wipers don't work, etc.
XJ93 08-23-2013 11:49 AM
Have you checked fuses? Check for power at the harness connector on the column and report back.
mturner0111 08-24-2013 08:53 AM
Found the problem the relay under the hood on the firewall had a melted wire at a fuse link I cut this out an replaced it and everything is working fine again!
XJ93 08-24-2013 11:21 AM
Way to go. Glad it was something relatively simple.
The time now is 07:46 AM.
