Steering Column Lock Pin Spring - JeepForum.com
post #1 of 7 Old 01-09-2014, 03:04 PM Thread Starter
zainyD
I'm working on my father-in-law's YJ and tore into the steering column today so that I could replace the turn signal/windshield wiper switch when it arrives. While doing this I noticed a small spring in the column was broken. After a good deal or research I determined that it was called the lock pin spring.
See it here: http://www.steeringcolumnservices.co...pin-spring.php
I went to order one, but it's going to be almost $13 for one stinkin' little spring. Since it originally came with a manual transmission it doesn't seem that this part of the column is needed/used. Is that correct?
May question is whether or not I can get by without spending $$ unnecessarily.
Thanks for your help.
zainyD is offline
post #2 of 7 Old 01-09-2014, 05:22 PM Thread Starter
zainyD
Well I talked the company and found out that the pin is actually what locks your steering wheel when the ignition is off and has nothing to do with gear selection.
Guess I'll have to bite the bullet and get one.
zainyD is offline
post #3 of 7 Old 01-09-2014, 08:29 PM
captainauti
pull the pin and spring out... i did on mine, but so i dont need a key in it when flat towing it.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #4 of 7 Old 01-09-2014, 11:02 PM
timatoe
timatoe's Avatar
I was thinking of doing exactly this.
timatoe is offline
post #5 of 7 Old 01-10-2014, 02:17 PM Thread Starter
zainyD
Does anyone have one laying around they'd be willing to part with? I'd like to have it on my father-in-law's Wrangler, but don't want to spend the $13 on a new one.
I called the local Jeep dealer and that spring has been discontinued.
zainyD is offline
post #6 of 7 Old 01-10-2014, 02:20 PM
BigDaddyJeepin
1991 XJ Cherokee
Find a junk yard and go get one out of a XJ. Same spring as YJ.
BigDaddyJeepin is offline
post #7 of 7 Old 01-10-2014, 02:39 PM Thread Starter
zainyD
That's a good suggestion, thank you. There are some U-pull-it junkyards in my area. I will check to see what they have in their inventory.
zainyD is offline
