Steering column ignition switch question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Steering column ignition switch question
Unread 03-22-2002, 06:56 PM   #1
Charlie L
I started having trouble turning my key to start the jeep, then it wouldn't turn all the way back to the lock position..so I took the steering wheel off to access the switch and stuff. I found a spring had worked it's way into the gears on the switch assembly. Does anyone know what those springs are for? Now I'm trying to put it back together minus the springs, but am having trouble figuring out where some rod goes. I think it's the high/low beam actuater rod, but it feels really loose..so I'm thinking it may have became disconnected at the other end. Anyone had the steering column apart..any advice is greatly appreciated. I'm almost ready to take it to the dealer and let them put the pieces back together.
Thanks,
Charlie
87 YJ, Wilderness Safari Rack
31/10.50 BFG's on 15X8 Atlas wheels, 1.25" shackle lift,
Weber Carb
Charlie L is offline   Reply With Quote Quick reply to this message
