Steering box or steering pump broken - JeepForum.com
post #1 of 4 Old 07-01-2011, 03:17 PM Thread Starter
macfero
Hi guys.
I own a 1990 Jeep Wrangler YJ 2.5 l.
Few days ago I noticed I had a leak oil in the right of the front left wheel. I looked more closely and I saw the leak under the hood. I checked the oil in the ship power steering. It was below the minimum. Until today there have been no oil leaks but the steering wheel turns hard.
The steering box might be broken ? It could be reconditioned?
Thanks
macfero is offline
post #2 of 4 Old 07-01-2011, 06:30 PM
Nickabis
I believe they can be rebuilt. I just added power steering to my 90yj with a 2.5 and used a cherokee ps box and pitman arm from the wrecking yard. Direct swap.
Nickabis is offline
post #3 of 4 Old 07-01-2011, 06:51 PM
bikerdude
1987 YJ Wrangler
Refill the oil reservoir and find the leak. It might be a hose or a connection etc.
bikerdude is offline
post #4 of 4 Old 07-01-2011, 08:40 PM
sbsg2005
The leak may be allowing air into the system which will render the system inoperable. Fill the system and fine the leak and fix it. After you fix it turn the wheel all the way to the left and fill the reservoir then turn it all the way to the right and and back to the left about 10 times checking the fluid level each time and filling up as needed. After doing this start the Jeep and see if you have power steering again. It is very rare that a gear box will need refurbished unless it leaks any play can normally be removed, so if you still have no power steering more than likely your pump has been damaged due to a lack of fluid.
sbsg2005 is offline
Replacing power steering pump broken bolt jesse18 TJ Wrangler Technical Forum 7 03-20-2011 10:56 AM
Leaky Power Steering Pump and Steering Clunk. KATSTJ TJ Wrangler Technical Forum 6 01-03-2009 05:03 PM
Steering suddenly shudders @ low speed...power steering pump? Please help pinpoint! captndiltz TJ Wrangler Technical Forum 2 08-20-2008 03:23 PM
Will durango steering pump work with the steering box. sitdwnandhngon YJ Wrangler Technical Forum 0 08-13-2008 07:20 PM
Chevy Power Steering Pump / Jeep Steering Box ? glenno YJ Wrangler Technical Forum 8 01-16-2008 01:40 PM
