Steering box seating - JeepForum.com
 1Likes
post #1 of 18 Old 08-17-2017, 11:19 AM Thread Starter
ad2_12
I just installed a new steering box but when I went to tighten the intermediate shaft to the gear box, you can see a little bit of the teeth on the box. Should it be seated all the way to the end of the spline? There is the main teeth that are about an inch long and then a little gap with no teeth and then another set of teeth that are about a quarter inch long. Should the column be all the way up to the front teeth? I normally take pictures before I disassemble for reference but I dropped the ball this time. I'll attach a picture. Any help would be appreciated.
15029901958641821204179_1502990256174.jpg   1502990280351195593986_1502990317261.jpg
ad2_12 is offline
post #2 of 18 Old 08-17-2017, 11:59 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
That bolt should go in the indent on the gearbox shaft. You need to lengthen the telescoping steering shaft.
Good luck with that. It's probably rusted in place quite well. There are threads on here that tell how other guys did it, but it isn't easy.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #3 of 18 Old 08-17-2017, 12:56 PM
Blob
Agree w/Mr. B....that bolt should seat in that channel.
Blob is offline
post #4 of 18 Old 08-17-2017, 01:06 PM Thread Starter
ad2_12
So it should cover the entire gap that is there or go all the way up to the gear box?
ad2_12 is offline
post #5 of 18 Old 08-17-2017, 03:49 PM
Mr.B
Mr.B's Avatar
Yes
Ham license:
Everyone is Welcome
Mr.B is online now
post #6 of 18 Old 08-17-2017, 07:22 PM Thread Starter
ad2_12
So go all the way up and almost touch the gear box?
ad2_12 is offline
post #7 of 18 Old 08-17-2017, 08:51 PM
Mr.B
Mr.B's Avatar
Yes
Ham license:
Everyone is Welcome
Mr.B is online now
post #8 of 18 Old 08-17-2017, 11:05 PM Thread Starter
ad2_12
Thank you for your help. I'll work on seating it the rest of the way
ad2_12 is offline
post #9 of 18 Old 08-18-2017, 08:31 AM
mark1305
mark1305's Avatar
Your questions sound like you are focused only on whether to slide the shaft all the way to the box. As pointed out above, you want to remove the bolt, position the shaft so that the bolt goes back in through that groove around the gearbox shaft. That will be a lot closer to the box, although not necessarily touching against it.
The bolt is probably blocking you from sliding the shaft further, as it should. It goes in after its hole lines up with the groove and effectively "pins" the shaft's clamp in place.
timatoe likes this.
mark1305 is offline
post #10 of 18 Old 08-18-2017, 10:45 AM
timatoe
timatoe's Avatar
Exactly, it won't go all the way down with the bolt in.
timatoe is offline
post #11 of 18 Old 08-18-2017, 06:44 PM Thread Starter
ad2_12
I was making my adjustments with bolt out but come to think of it, I had the steering wheel strapped in place and I wonder if that had any effect on me being able to slide it further. S o if in understanding it correctly, the bolt hole should be lined up with where the gap in the teeth are. Is this correct?
ad2_12 is offline
post #12 of 18 Old 08-18-2017, 07:08 PM Thread Starter
ad2_12
Update:
I just got back from trying to adjust the column. I got it to go considerably further down and couldn't get it to go down any further. Let me know if you think it is seated far enough so I can tighten the bolt up. Thanks.
ad2_12 is offline
post #13 of 18 Old 08-19-2017, 09:22 AM
Mr.B
Mr.B's Avatar
Nope, not far enough. Like I said in my first post, that steering shaft that you're attaching to the gearbox is telescoping. It's a PITA to get to move though.
See the red arrow in this pic? that is where the shaft will telescope.
Do some searching, there's a few threads that will tell you what guys did to get it to move.
Ham license:
Everyone is Welcome
Mr.B is online now
post #14 of 18 Old 08-19-2017, 09:48 AM
Mr.B
Mr.B's Avatar
Here's a couple of threads that might help you. It took me just a couple minutes of searching to find them.
http://www.jeepforum.com/forum/f12/c...shaft-4131409/
http://www.jeepforum.com/forum/f12/s...tions-4090545/
Ham license:
Everyone is Welcome
Mr.B is online now
post #15 of 18 Old 08-20-2017, 11:37 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
A vice, torch and a BFH will get you there. Eventually.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
