steering box mount stripped - JeepForum.com
post #1 of 4 Old 09-05-2011, 05:02 PM Thread Starter
steelman10
My steering starteted to act strange lately so I crawled under to look. both of the bolts on the bottom of the gear box mounting bracket that go into the frame were missing. when I went to replace them one just fell out. Any easy fix.?
steelman10 is offline
post #2 of 4 Old 09-05-2011, 05:06 PM
tdewit
If the threads are stripped, why not replace the bolts with grade 8 bolts and nuts?
tdewit is offline
post #3 of 4 Old 09-05-2011, 05:10 PM
srdart67
You could smother the ends in jb weld or panel bond but I would just get a new gear box to be SAFE. I had mine come off the frame rails goin down the highway and it pitched me on my side!
srdart67 is offline
post #4 of 4 Old 09-05-2011, 06:18 PM
nzpete
Unfortunately, the "nut" is a four-sided nut that is welded to the frame from the inside. I had one break loose and the only way to fix was to use a torch to cut an access hole in the side of the frame adjacent to the mounting hole. Then, weld another nut over the hole, then weld the access hole shut and grind to pretty it up.
It isn't very difficult, but you do need the torch, the welder and the skills to do the job. Otherwise, you'll have to pay someone else to do it.
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
stripped body mount nut help J03_TJ TJ Wrangler Technical Forum 7 03-01-2010 02:50 PM
stripped gas tank skid mount yarmish TJ Wrangler Technical Forum 3 11-21-2009 03:37 PM
'01 stripped body mount bolt Dans1tj TJ Wrangler Technical Forum 5 11-14-2006 10:53 PM
Body Mount Bolt Stripped Thump85 TJ Wrangler Technical Forum 21 09-25-2006 09:25 AM
Stripped Body Mount fundabug TJ Wrangler Technical Forum 4 09-16-2006 12:17 PM
