Steering Box Mount - JeepForum.com
post #1 of 2 Old 08-21-2011, 11:10 AM Thread Starter
nzpete
Steering Box Mount
I replaced a manual steering box with power steering and I'm having problems with the underside mounting bolts becoming loose over time.
The first time this happened it actually broke a bolt. This second time, I caught it before it became a big issue as I discovered it during replacement of the high pressure line.
I've torqued to spec, but have not used thread locker. I plan on removing the current bolts, applying thread locker, and then re-torqu.
Is this a common issue? If so, is there a common fix?
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #2 of 2 Old 08-21-2011, 11:46 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Can't say I've heard it being a common problem. Check the frame around the mounting holes to see if there are any cracks. If everything looks good, put a few drops of blue thread locker on the bolts like you were thinking.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
Steering Dampener Mount Thunderstrike JK Wrangler Technical Forum 10 05-03-2009 08:45 PM
high mount steering???? MUDDY94 YJ Wrangler Technical Forum 1 04-16-2009 07:59 PM
Power Steering Mount problem meBrian YJ Wrangler Technical Forum 2 03-02-2009 04:20 PM
Steering binding on trackbar mount servozn TJ Wrangler Technical Forum 1 11-15-2008 04:31 PM
steering stabaliser mount???? cincytj TJ Wrangler Technical Forum 3 02-15-2006 10:56 PM
