Steering box... - JeepForum.com
post #1 of 4 Old 05-04-2011, 08:00 PM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Steering box...
How do you remove it? I can't see how the lines go in or how it hooks to that steering u-joint. Do just those two frame side bolts hold it in?
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #2 of 4 Old 05-04-2011, 08:18 PM
92 Green YJ
92 Green YJ's Avatar
Umm, no. It's kind of a pain, with the stock fenders I am sure it will be even tougher. There are two lines that go into the top, the pressure and return line. When I removed mine the metal lines both twisted and broke so I had to get replacements. Tried everywhere and napa ended up having them finally. Then there is the small bolt that holds the steering shaft to the spline, obviously the pitman arm. Then four bolts hold it to the frame and a couple more to the frame plate bracket
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #3 of 4 Old 05-05-2011, 10:54 AM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Anyone got a write up or pics of what comes first?
Poke is offline
post #4 of 4 Old 05-05-2011, 11:25 AM
muddy93
1987 FSJ Wagoneer
well, I don't have a write up, or any pics, but here's what I remember from when I pulled mine off to rebuild it;
The steering shaft has a splined "clamp" thing on the end of it. You have to fully remove the bolt from that clamp, and it will just slide off of the box (That is, assuming that the slip joint in the shaft isn't siezed, and you can actually compress the shaft.) If you can't compress the shaft, just remove the clamp bolt, and you can pull the box out of the shaft once the box is un-bolted from the frame.
I found it much easier to disconnect the lines from the pump and res, and remove the box with the lines attached. Once the box is removed, you can place it in a vice, and it's much easier to remove the lines.
You will also need to remove the pitman arm. It can be removed without a puller, but having a puller makes it a lot easier.
And to remove the box, IIRC, there are 4 bolts that go in from the outside of the frame.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
Slight hitch in steering after power steering gear replacement. chip80 TJ Wrangler Technical Forum 2 10-04-2009 12:49 PM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-09-2009 11:20 PM
97 wrangler with manual steering, need donor info for power steering. anarchyfor2 TJ Wrangler Technical Forum 7 01-12-2009 07:12 AM
Steering suddenly shudders @ low speed...power steering pump? Please help pinpoint! captndiltz TJ Wrangler Technical Forum 2 08-20-2008 03:23 PM
lubricating steering linkage, steering and suspension ball joints? losfreddy TJ Wrangler Technical Forum 4 03-14-2006 04:39 PM
