Steering - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Steering
Ruffstuff Axle Simple Swap Kit!Even Better Heim Pricing! From RuffstuffToxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 02-27-2014, 11:57 PM   #1
zte87
2.5 POWER!
zte87's Avatar
IF you had to choose between the more cross over steering v setup and the rr hysteer which would go with and why? I plan on ordering steering in the morning and could use the input! Sent from my iPad using JeepForum
93 jeep yj bds 5 inch springs 5/8 boom shackles in the rear, locked front and rear dana 44/60 with front and rear chromoly shafts full cloak armor and 40 inch toyo's
january 2013 yjotm winner!
2013 yjoty winner!
http://www.jeepforum.com/forum/f22/m...build-1272253/
94 jeep zj bb lift, 31-10.50-15 toyo at2s, magnaflow exhaust!
zte87 is offline   Reply With Quote
Unread 02-28-2014, 12:22 AM   #2
Overhead
You built a 4cyl?
Overhead's Avatar
I run this with a flipped tie rod. it's Stupid strong, off the shelf components, and easy to find spares http://www.ballisticfabrication.com/...ds_p_1338.html
Between your two choices I say for M.O.R.E. or Ballistic.
Overhead is offline   Reply With Quote
Unread 02-28-2014, 05:25 AM   #3
zte87
2.5 POWER!
zte87's Avatar
I am already running a otk gm 1 ton setup but have plans to go a soa some day and will need the clearance for the new front 44.....
2013 yjoty winner!
Unread 02-28-2014, 07:03 AM   #4
Bong_Holyeo
I did cross over steering with my SOA by using WJ knuckles. The big brakes are a plus too.
Bong_Holyeo is online now   Reply With Quote
Unread 03-03-2014, 04:59 AM   #5
94SaharaGa
Hey ZTE87 could you post some pics of your current setup. I finished building my 1 ton tre setup this past weekend and went otk. The tierod clears the diff cover but hits the factory stabilizer mount before reaching full lock. Did you have to cut that mount off the axle. Thanks
Shawn-1994 Sahara 5 spd 4.0 H.O. 4:10 gears, e-locker in rear,3" skyjacker lift, 3" body lift, 1" shackle lift, 35" KM2's on 15x10 soft 8's, GTE front bumper with brush guard, Home-made rocker guards with steps, Home-made Rear bumper/Tire swing with ammo boxes for storage.
94SaharaGa is offline   Reply With Quote
Unread 03-03-2014, 05:27 AM   #6
94SaharaGa
Scrolled through your build thread and found my answer and your pics on page 98. Thanks
Unread 03-03-2014, 06:57 AM   #7
zte87
2.5 POWER!
zte87's Avatar
Sorry I just now saw your posts, if you want any more specific pic let me know! On a side not I have m.o.r.e cross over steering ordered!
2013 yjoty winner!
Unread 03-03-2014, 07:50 AM   #8
Norcal_chris
Norcal_chris's Avatar
The inverted T setup is less than ideal. I would hardly consider that even an upgrade since it is the same factory setup.
The RR setup uses that same idea.
I would say it would be more worth your while to run the JB4x4 bracket on the pass side and keep the tierod at the stock location. If you run a .250 wall tierod it is gonna take a lot to mess it up.
2.5/doubler,D60/14bff,104WB,H1s,39.5IROKS
Norcal_chris is offline   Reply With Quote
Unread 03-03-2014, 01:24 PM   #9
mmbtv
I use this setup also when I went to 3-link; way better than stock and M.O.R.E.
mmbtv is offline   Reply With Quote
Unread 03-03-2014, 02:06 PM   #10
'92 vegas YJ
R.I.P. Ratmonkey
'92 vegas YJ's Avatar
What makes this better than the MORE setup? Just because you get bigger brakes? MORE uses a double shear setup with hiems, which in my opinion is better than the tapered TRE WJ knuckle. Just my opinion though.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
'92 vegas YJ is offline   Reply With Quote
Unread 03-03-2014, 02:28 PM   #11
mmbtv
The WJ setup w/ Ruff Stuff cross over just plain turned better for me, tighter smoother and less binding and the bigger stronger brakes is a bonus.
The M.O.R.E. setup put things in the right place for a springover but the feel was about the same as stock.
I think it is more the geomerty of the WJ knuckle.
Strength was/has not been in issue for me on either one.
Unread 08-17-2014, 11:52 AM   #12
zte87
2.5 POWER!
zte87's Avatar
OK I am bumping my own thread, I went with the m.o.r.e bracket and 3/4 inch him setup from ruff stuff any ways to I need to have my drag link perfectly flat or parallel to the tirod with this set up?
2013 yjoty winner!
Unread 08-17-2014, 01:10 PM   #13
youngjeepr
youngjeepr's Avatar
No you don't need to have it parallel with the tie rod.. But it would be ideal. Your angles look just fine.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
Utah Jeep Crew
Build Thread
youngjeepr is online now   Reply With Quote
Unread 08-17-2014, 09:29 PM   #14
zte87
2.5 POWER!
zte87's Avatar
OK I was told if it wast it would cause bumpsteer!
2013 yjoty winner!
Unread 08-17-2014, 09:43 PM   #15
youngjeepr
youngjeepr's Avatar
It can cause bump steer if it's at a bigger angle but you are no where near close to that angle. Your steering should be solid!
Utah Jeep Crew
Build Thread
