steel horse hard tops? - JeepForum.com
post #1 of 17 Old 01-10-2002, 11:32 AM Thread Starter
jeeping18
iv been looking into the sierra and targa top from steel horse and was wondering if anyone had any info about the 2 tops? id appreciate any thoughts!
1991 YJ
-4.0L I6
- BORLA CAT BACK EXAUST
-2.5 INCH PRO-COMP LIFT
-31X10.50 PRO-COMP MUD'S
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
jeeping18 is offline
post #2 of 17 Old 01-10-2002, 01:05 PM
HUBDEEP
HUBDEEP's Avatar
1987 YJ Wrangler
Don't buy anything from Steel Crap. It won't fit, it'll leak, or will have something else wrong with it. All of their stuff is crap.
My $.02
-Jason
'87 YJ- - D44's, 8" SOA , 5.38's, Locked f/r, 36" IROK's and a bottle opener...
clicky-->
clicky-->
HUBDEEP is offline
post #3 of 17 Old 01-11-2002, 03:55 PM
QueenYJ
I will tell you this much. I have installed the Steel Horse Targa Top on my baby for the winter and I have to say I was in total shock. Let me preface this by saying I would rather rather drink vinegar than order anything from Steel Horse. I love this hard top! I also had to order the window sliders because I sold my full steel doors and kept the half steel doors. Amazingly everything fit absolutely perfectly. No gaps, or leaks whatsoever, no kidding. It is also nicely carpeted on the inside making it mucho quieter than the factory version. The only, repeat, only reason I bought this was because I had to have the targa top feature. I hate having any top on but I'll most likely be moving back North again and I'll need the hard top. As far as the window sliders they were redesigned and improved for this year but the rear section is still the only section that opens. This has not been a problem, the opening is large enough for what I've needed to do. This top is secured entirely with all quick release latches, no bolts at all and it has a ton of rubberized weather stripping throughout. When I say it was a perfect fit I mean it. I'm still pinching myself because I was so pleasantly surprized. The only other targa out there is made by Pavement Ends and it is a knock off of the Steel Horse. If we all think Steel Horse is bad I would say doubly so for Pavement Ends. I'm tellin you this is a great versatile top for the money, for real. There are some rocket scientists out there who have messed up the finishes on their targa's and it is not a Steel Horse problem. The directions specifically say not to use waxes or armour all on the finish as they are not silicon based such as the recommeded Black Magic cleaner/protectant. I certainly have no intention of sounding like an infomercial for the Steel Horse Targa top but mine really is that good. Just my .02
93 4.0L YJ With lots of mods and goodies
QueenYJ is offline
post #4 of 17 Old 01-11-2002, 04:35 PM
Darko
Thats good that someone liked that hartop.
I DIDN'T!!!!!!!!!
One of my buds installed a 2 piece hardtop with upper halfes from steel horse. It fit like crap!! I like the look on the hard top, but its the biggest piece of **** ive ever seen. ALl of the screws holding the 6 big paddle locks at the tub are stripped, and the two latches that hold to the windshild frame are messed up, one of them holds fine, but the other is wayyy to loose, and doesn't clamp down anything. One of the clips holding in the front half ripped out on the same side as the large paddle lock, so when you drove that one side lifted 3" in the air, so we used 16GA wire to tie it down to the rollbar. The front section doesn't seal out wind, and driving the Jeep is like being strapped to the wing of a airplane. The Fiberglass Uppers are garbage. They wouldn't close all the way becuase they rubbed the top of the hardtop. There are 3 big knobs that hold them into the door. For those 3 big knobs to bolt in their are plastic pieces that slide into the half door, they all broke, all 6 of them on both sides, and they are not fastented to the doors any more. THIS TOP IS A PIECE OF ****. DO NOT BUY IT. I'm happy QueenYJ had good luck, but a company that produced this piece of garbage, then sells it for $2000 should be killed, then killed again. What a piece of garbage. Their soft tops are **** too. DO NOT BUY IT!!!!!! I saw Fleet air hardtops in the catalouge, and thats the route I would take If I went for a aftermarket hard top. You should be able to find a factory YJ hardtop for less than $800, that Is the route I would take.
PS. DON'T BUY THE FU*KING HARD TOP
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #5 of 17 Old 01-11-2002, 05:01 PM Thread Starter
jeeping18
thank you both for the info, but now im so damn confused i dont know what to think. but i do know darko was very persuasive. ill probably start to look for used tops, ill keep you updated
1991 YJ
-4.0L I6
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
post #6 of 17 Old 01-11-2002, 05:15 PM
rayray
rayray's Avatar
If you value your money, stay away from "Steal" Horse. I have yet to personally see anything from them that was worth a s***.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #7 of 17 Old 01-11-2002, 11:23 PM
ImNotRyan
ImNotRyan's Avatar
funny, this should come up... i was just reading reviews on 1994 jeeps and one of the cons one review listed was "some aftermarket parts are junk (steel horse)"
i have no personal experience with this company... but theres enough warning signs to steer clear as far as im concerned
1979 CJ-5
1987 Chrysler 5th Avenue
ImNotRyan is offline
post #8 of 17 Old 01-11-2002, 11:58 PM
Darko
worth a s***.
Actually, I got matching front and rear tube bumpers, They are the nicest looking bumpers I've seen, and are in stainless finish. I have also heard good things about the seats, and I like their Jumbo center console.
It is sick though, that for $2000 you get a piece of Junk that lasts 1 year
Darko is offline
post #9 of 17 Old 01-12-2002, 12:40 AM
-D-
I have a steel horse center large center console. It is basically the BIGGEST thing you can possibly fit as a center console and works pretty good, plenty of room. I hear a lot of bad things about steel horse so I'm afraid of getting the sierra top for my YJ, but I was looking at it as well. I'd be interested to hear from other people with this top. Someone at school has one and it looks fairly nice on his YJ, but I haven't talked to him about it.
-D-
-D- is offline
post #10 of 17 Old 01-12-2002, 12:30 PM Thread Starter
jeeping18
so far all i hear is not to get a steel horse top but does anyone have any hard tops they like? if anyone knows about the PAVEMENT ENDS hard top letme know!
thanks
1991 YJ
-4.0L I6
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
post #11 of 17 Old 01-14-2002, 01:12 PM
rayray
rayray's Avatar
thanks
IMO, first pick would be a factory YJ top. If that's not an option, get a factory CJ top.
rayray
rayray is offline
post #12 of 17 Old 01-14-2002, 07:21 PM
RCHavok797
RCHavok797's Avatar
Be very careful when purchasing anything from Steelhorse. I don't know what their problem is but they can't seem to follow factory guidelines in manufacturing most of their products. Hardly does anything fit wihtout having to modify it somewhat. The only good luch I have had with them is buying their acrylic accessories like the fender guards or rain guards.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #13 of 17 Old 01-14-2002, 07:44 PM
Darko
why don't you check out fleet air hardtops, they are a hundered bucks more, but look like a real nice hard top. They are also 2 piece.
Darko is offline
post #14 of 17 Old 01-14-2002, 08:37 PM
axle
i think everyone has said plenty, so i won't give you my complete list of steel horse garbage. i've sent most of the accessories i purchased from steel horse back..... and their customer service is about as good as their products..
axle is offline
post #15 of 17 Old 01-17-2002, 12:49 PM Thread Starter
jeeping18
thanks for all the info, but i think im gonna look for a yj factory hard top or lookin into the fleet air 1 piece if anyone has one let me know!
1991 YJ
-4.0L I6
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
Steel Horse Hard Top Question!!! LewJ TJ Wrangler Technical Forum 42 02-04-2015 07:20 AM
Steel horse hard top door pins MoTownYJ YJ Wrangler Technical Forum 1 09-06-2009 07:40 PM
steel horse soft tops builderpaul TJ Wrangler Technical Forum 2 05-10-2006 09:04 PM
Steel Horse???? Sidewalkman YJ Wrangler Technical Forum 11 07-05-2003 09:44 AM
Steel Horse PLUR TJ Wrangler Technical Forum 9 04-22-2002 12:58 PM
