state laws - JeepForum.com
post #1 of 15 Old 12-22-2007, 04:26 PM Thread Starter
bashbro
state laws
hey all .. im trying to figure out what kinda seats and harnesses i want to put in my YJ ... i live in PA and want the thing to be daily driver capable so inspected and insured and everything ... how do i find out whats legal as far as harnesses and 3,4,5 point harnesses ... im most likely looking at a 3 or 4 point. but i beleive something said it needs to be retractable ... would the corbeau 3 point retractable harness be legal? any help is much appreciated as always
bashbro is offline
post #2 of 15 Old 12-22-2007, 04:29 PM
jaw41272
jaw41272's Avatar
Look at it this way, if you had originally a 3 point restraint, you must have a 3 point restraint or better, you can't go from lap/shoulder to just lap, however you can go from lap/shoulder to a full harness, why ??? Because you are allowed to improve the safety, you just cannot remove the safety.
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
post #3 of 15 Old 12-22-2007, 04:32 PM Thread Starter
bashbro
ur very right ... i was just wondering cuz there are lots of stupid rules out there and i dont know if things like this need to be DOT approved and what not...
bashbro is offline
post #4 of 15 Old 12-22-2007, 04:38 PM
jaw41272
jaw41272's Avatar
Well of course any restraint system you use will need to be DOT approved, you can't even change a marker light lens to anything other than DOT approved.
jaw41272 is offline
post #5 of 15 Old 12-22-2007, 04:57 PM Thread Starter
bashbro
im looking on every website but none say DOT approved - how do i find out what is and is not ... ideally i want the 3 point retractable corbeau harness
bashbro is offline
post #6 of 15 Old 12-22-2007, 04:57 PM
timatoe
timatoe's Avatar
DOT approved and "Street Legal" are two different things. But to the question at hand, stop by a local Highway Patrol office and ask them, they should be able to point you in the right direction.
Also, some guys run their stock seat belts for the road and then have a harness for the trail. Just something to think about.
timatoe is offline
post #7 of 15 Old 12-22-2007, 05:01 PM
VT2BAD4U
Check with the vendors of the products you are concidering. Here, the belts and seats are "supposed" to be DOT compliant to pass inspection.
Don't cheap out,(half a-- install) if going with the competition type seats and belts route. You won't be happy with the results. There are a lot of posts here on setups that are less than satisfactory. *Use the search feature.*
I made custom seat brackets for mine to get them to fit just right. The stock brackets where too narrow, plus put the seats too high into the steering wheel with the high side bolsters.
They are Tuner FX seats that I got from a place going out of business. The belts are Corbeau three points. Do lots of homework before you buy! You'll be happier in the end. Oh, and try out the seats before you buy if you can. The seat you like the looks of, may not fit you or feel as good as it looks.
VT2BAD4U is offline
post #8 of 15 Old 12-22-2007, 07:06 PM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
install whatever harness you like and just keep the stock seat belts in. they shouldn't conflict with the install anyway. but to use a 3, 4, or 5 point harness properly will defanitly limit your movement in the jeep. if properly used, you shouldn't be able to lean forward which will make you loosen them some. basically making them useless. If you want them just for off-roading, like i said in the beginning, just keep your stock seat belts for daily driving. that way you don't have to worry about passing inspection. and to be able to properly mount them, (you probably already know this, but just in case) you will need to have some DOM tube about 1.5feet below your neck behind the set to attach the shoulder straps and most usually like to mount the lap belts to the cage roll bars that go past the seats (on custom cages).
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #9 of 15 Old 12-22-2007, 07:11 PM Thread Starter
bashbro
i have a stock standard cage - not the family style- and if i go the harness route i was gonna purchase the bolt in harness bar from 4wd.com to mount the shoulder straps and i was assuming i would mount the lap straps to where the stock ones used to be ... bad plan? not too bad of a plan but could be better?
bashbro is offline
post #10 of 15 Old 12-22-2007, 07:43 PM
Jesse-James
Jesse-James's Avatar
1989 XJ Cherokee
If you have inspection they wont pass you with 4 or 5 pt. harnesses only.
Live in SE WI? ----->
Jesse-James is offline
post #11 of 15 Old 12-22-2007, 08:37 PM
Solus
What he said. In my state they wont pass you if you don't have the stock or at least a stock seatbelt in. I think however you can get away with it if the seatbelt is just in there, like attach it when you go to get inspected. If any of that actually makes any sence.
Solus is offline
post #12 of 15 Old 12-22-2007, 08:47 PM
RoverJeep90
I know a guy here in PA that runs Corbeau racing seats with the 3 point harnesses. I don't think he has the stock seatbelt in, but I never really checked. And he's been running this setup for a while, so he must have passed inspection at some point.
1990 Red YJ 2.54 L (Rebuilt) 5 Speed with 94 rollbar | Dynomax Exhaust | Luk Clutch
2.5" Old Man Emu over 31x10.50 BFG MTs on 15x8 AR 767s | 1" Daystar Body Lift
Two Tops | Full and Half Doors | KC Daylighters | Hella 5500 | OME Steering Stabiliser
Sony CDX-GT300 | Kicker ZX500.1 | Kicker ZX350.4 | Kicker ZX200.2 | Kicker L5 Solobaric Sub | Kicker 6x9's | Apline 6.5's | Boston 4x6's
Truckstop CB Antenna | Class 3 Hitch
RoverJeep90 is offline
post #13 of 15 Old 12-22-2007, 09:08 PM
doug_1994
doug_1994's Avatar
Originally Posted by bashbro
i i was gonna purchase the bolt in harness bar from 4wd.com to mount the shoulder straps and i was assuming i would mount the lap straps to where the stock ones used to be ... bad plan? not too bad of a plan but could be better?
It doesn't matter what the cage, or any kind of bars for mounting. Its all in the seats.
If you mount a bar below your shoulders, your seats will have to have harness "holes" in them. If you do not do this, you risk breaking your back in a rollover.
As for your original question. I had RJS four point harnesses in my YJ here in Pa. I never had any trouble with getting my jeep inspected.
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline
post #14 of 15 Old 12-22-2007, 10:37 PM
SWAMPRNR
TX only requires front seat belts.Doesn't matter what kind as long as its a working and adjustable seat belt.But now the seat is optional and not required for inspection
A Big Hammer Can Fix Anything....
SWAMPRNR is offline
post #15 of 15 Old 12-22-2007, 11:05 PM
jeeepguy
jeeepguy's Avatar
Wow... lots of good info and lots of bad info.
a) Harnesses can be purchased that have retractors built into them for daily use and for serious riding. Both Corbeau and Schroth make 3 and 4 point systems that work as retractables for the shoulders when used for the street and "lock" for use off-road. Both are excellent products and pass any states requirements for safety equipment.
b) DOT certification is NOT a requirement for any equipment that is sold aftermarket. DOT certification only applies to OEM as this is a Fed requirement for safety certification on the OE manufacturing level.
c) Proper harness mount placement is not specific to a measurement, rather it needs to be mounted in a way that in a high speed crash, the shoulder straps do not lock down to compress your spine. The standard way to avoid this is to place the rear harness attachement points so that the pressure on the "down pull" of the straps does not directly occur at the shoulders but rather at an angle not to exceed 15 degrees from parallel to the shoulders. Thus you could mount a "strap support behind your shoulders so that the straps pass over them and then turn down and attach to the floor of the heep. You need to make sure the strap bar is VERY sturdy if you do it this way. Another method is to do what I did and run the straps to the rear of the rig and attach them there.
d) If you want to read up on the OEM requirements for seat belts, you can read it all here: NHTSA Seat Belt Requirements
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
Door laws, state to state idencustom TJ Wrangler Technical Forum 26 03-06-2013 03:27 PM
Lift laws: state by state kaybone Wrangler General Discussion 11 04-09-2009 05:31 PM
====LIST of STATE MIRROR LAWS==== dz1087 Wrangler General Discussion 6 07-09-2008 11:41 AM
NJ State Windshield Laws 95GreenWrangler Wrangler General Discussion 22 06-22-2008 02:44 PM
TeraFlex or RE and State Laws elmo510 TJ Wrangler Technical Forum 6 07-12-2004 06:58 PM
