Startup RPM - JeepForum.com
post #1 of 11 Old 08-22-2005, 11:41 AM Thread Starter
Alfons
Startup RPM
When I first start my '91 YJ it runs at about 1200 - 1400 rpm for a few seconds and then settles on a normal idle. I've heard of the same problem on jeeps with carbs, so it can't be the injection system - I've thought of a couple of possibilities like the throttle position sensor and the idle step motor. Any suggestions?
Alfons is offline
post #2 of 11 Old 08-22-2005, 11:43 AM
Why J?
Why J?'s Avatar
mine has always done that i thought it was normal operation.
Why J? is offline
post #3 of 11 Old 08-22-2005, 11:49 AM
atomicmoose
Just call me Moose
atomicmoose's Avatar
that actually seems normal to me. Do you pump the pedal before starting it?
What are the engine specs on your jeep?
atomicmoose is offline
post #4 of 11 Old 08-22-2005, 12:01 PM
rsoffar
mine does that every time i start it cold but after it warms up and say i make a quick stop it wont do it then.
94 4.0 auto, tj flares, 31x10.5 bfg mt, a to z rockers
"Pc load letter.... what the f#*k does that mean!?" Michael Bolton
rsoffar is offline
post #5 of 11 Old 08-22-2005, 12:02 PM
zolon
zolon's Avatar
I would imagine that being normal, as every car I have owned did that. From my understanding it is the buildup of pressure in the fuel system. It does it on purpose for cold starts.
Could be wrong though.
2012 Jeep Wrangler Sport - Silver - Build Date 2-27-2012
1999 Safari Zanzibar 38' Diesel Pusher (Full Time Home)
zolon is offline
post #6 of 11 Old 08-22-2005, 12:38 PM
that_1_guy
Same as everyone else: Mine has always done it.
'94 Red YJ
4-banger (2.5L) 5sp/3" bl with 31" bf/mt
/l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_)
Red Jeep Club Member #318 | Low Output 4-Banger Club Member #46
that_1_guy is offline
post #7 of 11 Old 08-22-2005, 03:39 PM Thread Starter
Alfons
Thanks for all your input - the explanations sound logical so I guess I'll stop looking for a "fix"
Is it also normal for a 4.0 Liter Fuel Injection Engine to need several turns (4 to 6) before starting? I had thought this may have been part of the "higher startup rpm" situation, but obviously not.
Alfons is offline
post #8 of 11 Old 08-22-2005, 03:41 PM
zolon
zolon's Avatar
Depends. Some days my dad's I6 will start when he just taps the keys. Other days it takes a few turns.
I think it's the weather to be honest. My 4 squirrel banger is the same way.
zolon is offline
post #9 of 11 Old 08-22-2005, 05:53 PM
kimvansa
seems normal like they all said, I get this when you nearly stall on hill climb pull aways, still trying to get used to the foot rear brake thang, release clutch and accelerate all 2gether (thats 3 feet to me I still only got 2! so whats the trick?)
kimvansa is offline
post #10 of 11 Old 08-22-2005, 05:56 PM
kimvansa
b4 you all come back with its a hand release now and again i need those 3 feet!
kimvansa is offline
post #11 of 11 Old 08-22-2005, 08:48 PM
TellyDSP
Poland and PPV!!!!
Mines done it ever since I swapped in the 4.0 TB.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
oil pressure lag at startup? .apollodorus. TJ Wrangler Technical Forum 10 07-05-2007 03:39 PM
Should CEL come on during startup? Brandon Iain TJ Wrangler Technical Forum 2 04-26-2007 01:12 PM
A/C screach at startup vato_loco_quas TJ Wrangler Technical Forum 5 11-04-2005 06:26 PM
TJ Stalls as Startup supr_bikr_99 TJ Wrangler Technical Forum 2 08-26-2005 08:11 AM
rough on startup seachange TJ Wrangler Technical Forum 1 08-07-2005 09:11 PM
