starts without a key now wont start - JeepForum.com
post #1 of 9 Old 06-27-2013, 08:25 PM Thread Starter
max1010
My 89 hasn't had a key in the ignition since I purchased it. It usually will start but sometimes it will just click when I turn the switch. I can repeatedly turn the switch on and off until it starts but now it is dead. Is the switch finally bad or does it drain the battery since it isn't working correctly?
max1010 is offline
post #2 of 9 Old 06-27-2013, 10:34 PM
superj
I would say the swich is probably bad but put a multimeter on the battery to see the charge and you can test some other wires to verify the switch is bad before you buy anything unneeded
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 9 Old 06-27-2013, 11:03 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I'll go out on a limb & say the switch was bad before you bought it.
Not sure what would have had you think it was okay to use it without a key unless somebody gave you some sort of BS story.
Joe Dillard is offline
post #4 of 9 Old 06-27-2013, 11:15 PM
dancytron
When you say it clicks, does it click in the steering column from turning the key, or does it click under the engine from the starter solenoid or starter?
If it is clicking under the engine, then it is either the battery or the starter solenoid or maybe the starter. If it clicks in the steering column, then it might be the switch.
Turn the headlights on. When you try to start it, do the lights dim? If yes, the ignition switch is probably working and it is probably the battery, starter or starter solenoid.
On my 1990, the starter solenoid is mounted to the starter and they are sold together. I think earlier ones might have the starter solenoid on the firewall, like old Fords.
dancytron is offline
post #5 of 9 Old 06-28-2013, 06:56 AM
Rproject
1987 YJ Wrangler
THIS!
And yes - the older ones have the starter solenoid on the firewall.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #6 of 9 Old 06-28-2013, 11:24 AM
dancytron
I forgot the battery cables. It could be them too.
post #7 of 9 Old 06-29-2013, 10:30 AM Thread Starter
max1010
The battery and starter were both new last summer.
max1010 is offline
post #8 of 9 Old 06-29-2013, 11:29 AM
dancytron
Where is the click coming from?
I had a cheap rebuilt starter go bad on mine in about 4 months.
I'd replace the battery cables first if they don't look new.
post #9 of 9 Old 06-29-2013, 12:41 PM
XJ93
Where your key goes in is called the cylinder, on the top of the column behind the dash is the switch. Push the rod that goes into the switch and see how much movement you have. It's very possible that the switch may have slid out of position and is not making contact. The cylinder has to be replaced as well, you are just inviting trouble by not having a key.
XJ93 is offline
