Starts only with brake light signal? - JeepForum.com
post #1 of 3 Old 04-14-2012, 03:42 PM Thread Starter
ez805
I bought a '92 YJ with dash gauges missing and the original harness was spliced up. I replaced it with a 94 harness and now all the factory gauges i bought work, but it wont start with key. When I touch the brake or the hazard light it turns over and runs. All the connectors seem to match, but I guess the original owner mixed up a brake light wire with the ignition. I would appreciate any help as I need to smog it so I can register it by next friday.
ez805 is offline
post #2 of 3 Old 04-14-2012, 03:44 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Pretty sure I would just figure out which wires were starting it and get a push button switch for the starter and a toggle for 'on'. Hide them under the dash for security...
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 3 Old 04-14-2012, 03:50 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sounds like a great kill switch.
Luck Favours The Prepared
Anticanman is offline
harness , ignition , wiring
RT Turn Signal/Brake light tjtone TJ Wrangler Technical Forum 2 03-30-2007 12:27 PM
Turn Signal and Brake Light Jeep_Grrl TJ Wrangler Technical Forum 8 08-13-2005 03:24 PM
Brake light/signal issues ClarkAM1 TJ Wrangler Technical Forum 3 04-11-2005 11:18 AM
signal light goes on when I brake Decz TJ Wrangler Technical Forum 9 02-24-2005 06:20 AM
No Brake and signal light ayadov YJ Wrangler Technical Forum 2 05-26-2002 09:58 AM
