Starts fine then dies, I dont know why... - JeepForum.com
post #1 of 4 Old 10-16-2011, 03:40 PM Thread Starter
bluedaffy
My 4.2L Wrangler yesterday morning out of the blue started acting a little funky. It will start just fine, nothing at all out of the ordinary and then die after like 15 seconds of running at a smooth idle. Nothing sputters when it dies, it just simply immediately dies. Any help on this would be wonderful, I'll need to fix this problem by next week when I will surely need it for work and school.
Thanks,
bluedaffy
bluedaffy is offline
post #2 of 4 Old 10-16-2011, 07:34 PM
castorriver
sounds like a dirty fuel filter. Mine would start ok but sputter and die after a few seconds and a new fuel filter fixed the problem. It's a cheap fix and you probly need a new one anyway.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #3 of 4 Old 10-16-2011, 10:48 PM
all83mci
New fuel filter,.fuel pump, or adjust ur keeper screws. Also spray starting fluid around ur carb . If it seems to run faster suddenly u have a vacume leak around ur carb. Have u been kidding latley? If so mayb u need a new distributor rigor cuz it is forties by moisture.
all83mci is offline
post #4 of 4 Old 10-17-2011, 09:11 AM Thread Starter
bluedaffy
Thanks for the replies and although I am probably due for all the new junk you guys mentioned, the problem actually turned out to be an anti-theft switch on the back of the parking brake pedal that wasn't grounded. It frustrates me that is was something so small, but it makes sense because it was like the jeep was dying for no reason at all... (anti-theft shut down)
carb , dies , start , start problems
Won't start - Doesn't crank - Push starts fine Panici TJ Wrangler Technical Forum 12 04-06-2010 09:36 PM
Starts, Idles, Dies, Wont Start, Wont Start, Pump Pedal, Starts... REPEAT inniett YJ Wrangler Technical Forum 2 04-08-2009 05:13 PM
6cyl. Starts fine then dies? Whats the prob? brianOU YJ Wrangler Technical Forum 4 09-07-2008 07:51 PM
Idles fine, Shift in gear and it sputters and dies smitkev2 YJ Wrangler Technical Forum 5 04-24-2008 09:19 PM
TJ dies, then wouldn't start, then wouldn't idle, now runs fine. K1dS3ns4t10n TJ Wrangler Technical Forum 18 02-25-2007 09:38 AM
