starting problems, crank pos sensor - JeepForum.com
post #1 of 2 Old 11-06-2011, 09:04 PM Thread Starter
viperfanatic13
so heres what happened. i replaced my clutch master cylinder and while taking it for a test drive it just died. after pushing it to the side of the road i tried to start it, it cranked but wouldnt turn over. i figured it was either the fuel filter or pump but the fuel pump was still working and the filter was fine. i then checked to see if i was getting spark which i wasnt so i tested the coil and wasnt getting any power to it. i did a little research and found someone with the same problem and it was their crank position sensor. so i bought a new one and installed it. it still wouldnt start so i started testing everything again. now the coil had power but wasnt sending a spark to the distributer. so i bought a new coil installed it and it fired ran for about 2 or 3 minutes and then died and now im back to square 1. any thoughts???
viperfanatic13 is offline
post #2 of 2 Old 11-07-2011, 05:34 AM
Que89YJ
Que89YJ is offline
coil , crank position sensor , wont start
crank sensor.. HELP nickaldrich YJ Wrangler Technical Forum 8 06-22-2010 10:25 AM
2.5 starting problems. wont crank. obsessedjeeper YJ Wrangler Technical Forum 12 11-15-2009 10:29 PM
My 2.5 takes a while to start, is it the cam sensor or crank sensor!! Divebum TJ Wrangler Technical Forum 9 12-24-2008 12:38 PM
Crank or cam sensor problems? JimenyFKrickets YJ Wrangler Technical Forum 3 01-25-2008 10:06 AM
long crank before starting? ForkLift TJ Wrangler Technical Forum 6 10-02-2004 09:27 PM
