Starting issue - JeepForum.com
post #1 of 5 Old 08-14-2017, 09:24 PM Thread Starter
Snoopy3363
1993 WJ
Starting issue
93 2.5L. When cold, starts right up. you can turn off and start again with no problem. Drive for a bit and get motor to operating temp, shut it off and it will crank over but not start. Let it sit for a 1/2 to 1 hr. It starts again. any ideas. Mark
Snoopy3363 is offline
post #2 of 5 Old 08-15-2017, 12:25 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Welcome to the forum.
Do you have a Grand Cherokee(WJ), or a Wrangler(YJ), or both?
The first thing you should do is check for any engine codes. This is how you do that:
It could be a few different things. So check the codes and get back to us. I see you're getting help on another thread, but you should really get it here. Because that thread is about a different problem.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #3 of 5 Old 08-15-2017, 12:42 PM
RCtoo
I had a similar problem with my 2002 WJ...
Replaced the Transmission Sensor...
and Tran fluid & filters at the same time... had just bought the Jeep at 163k
No problem since... there are also some other suggestions on a thread I started a couple of weeks ago
Ray
RCtoo is offline
post #4 of 5 Old 08-15-2017, 11:28 PM Thread Starter
Snoopy3363
1993 WJ
thanks , I will check for codes and the trans sensor.
post #5 of 5 Old 08-16-2017, 04:51 PM
mike134
I'd head up to autozone and borrow the fuel pressure gauge. It is free if you leave a deposit at the desk.
Your fuel pressure may be too high to start up.
Get everything else you need to update your tuneup items.
mike134 is offline
