starting the 4.0 swap this weekend - JeepForum.com
post #1 of 9 Old 06-05-2008, 10:20 AM Thread Starter
mtn_wrangler
ok so with the unexpected death of the BA 10/5 im going to go ahead and do the 4.0 swap along with the ax-15 transmission. so heres where the questions come in. the engine is out of an 89 cherokee. its going into an 88 wrangler. i dont have the time to get the wiring diagrams and go through the wires myself since i need this thing running asap. so i was wondering if there was anyone that could lend a hand and tell me which wires i hook up to what just to get this thing running again. if gauges dont work its fine most of mine dont work as it is anyways.
thanks in advanced
joe
mtn_wrangler is offline
post #2 of 9 Old 06-05-2008, 10:34 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
You may want to ask this in the XJ section. That 4.0 is NOT the same 4.0 in YJ's, it is a RENIX 4.0. Very different electrical system and fuel system.
Here is a good RENIX reference thread: http://www.jeepforum.com/forum/f11/helpful-renix-links-563149/
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 9 Old 06-05-2008, 10:36 AM
LilViper95
LilViper95's Avatar
I did a 4 cyl to 4.0 swap a while back and in my research i was strongly advised to go with the 91+ 4.0 as the renix motor is less powerfull, less reliable and a much more difficult swap.
04 Ram 2500 5.9L 24v HO Cummins
LilViper95 is offline
post #4 of 9 Old 06-05-2008, 11:17 AM
atomicmoose
Just call me Moose
atomicmoose's Avatar
I can speak to the difficulty of the swap...
atomicmoose is offline
post #5 of 9 Old 06-05-2008, 12:19 PM
Blazin Den
see if this helps
http://www.jeepforum.com/forum/f12/4-0-swap-information-537763/
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
post #6 of 9 Old 06-06-2008, 08:37 AM Thread Starter
mtn_wrangler
ok from there i have two questions.
1. is there anyway i can get the wiring list still as this engine was free and i still am spending every waking moment to try and get the old engine pulled and new transmission from the junkyard and getting everything prepped?
2. if i find the wiring harness and intake manifold w/ everything i need will it just bolt onto the 89 head without issues?
sorry if i seem lazy i just really need to geet this done quick and right
post #7 of 9 Old 06-06-2008, 10:42 AM Thread Starter
mtn_wrangler
to the top
post #8 of 9 Old 06-06-2008, 11:17 AM
wendell
1987 YJ Wrangler
If your 88 has the 258, I would keep it. You could allways put a 4.0 head on it and efi, I wouldn't give up cubes. Yeah, for sure go with the 91 and up 4.0. Lots of parts availability and a better system. I love my old school 4.2, however the carb sucks, but thats an easy fix. The 2.5 isn't a bad engine if you give it some gear.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #9 of 9 Old 06-06-2008, 11:21 AM Thread Starter
mtn_wrangler
the 4.2 is failing smog and i will need to go through a referee station if i put a different carb on it i believe. and if i go through the referee station i rather just do it with fuel injection. and i want to use this engine because i have it already
help '91 jeep wrangler 2.5 not starting after I did the 4.0 throttle body swap countryboy15 YJ Wrangler Technical Forum 0 01-31-2010 05:59 AM
Help Jeep Not Starting After I Did Throttle Body Swap countryboy15 YJ Wrangler Technical Forum 4 01-31-2010 05:19 AM
starting 350 swap... couple questions. nelly97tj YJ Wrangler Technical Forum 11 01-16-2010 07:48 PM
need info for gear swap, starting point johnny9 TJ Wrangler Technical Forum 1 09-13-2009 10:37 AM
Not starting after p/s pump swap 92wrangler YJ Wrangler Technical Forum 2 01-09-2007 03:25 PM
