Starter? Solenoid? - JeepForum.com
post #1 of 9 Old 08-11-2006, 11:05 PM Thread Starter
z71offroader
z71offroader's Avatar
Starter? Solenoid?
every so often my jeep wont crank, but if i go hit the starter a few times she will.
this started early this summer probably in June. it started doing it more and more. so i replaced the solenoid and it fixed it. this month it started doing it again.....what is killing my solenoid? any ideas on this would be great!
Thanks guys!
93 YJ- SOA, R.E 1.5" Leafs, Custom paint, 35x16 Boggers,15x10 97 series rockcrawlers. Diamond plated interior and exterior, Tera SYE/CV DS, Herculined Tub, Bestop, Warn Bumpers w/ 9.5ti, 8.8" rear, D30 front, both ARB's with 4:88's, Super 88, Posi-Lok, Alpine Stereo, Tuffy Security, Hella Fogs, ProComp Spots, and much more.
07 2500HD D-Max CC LB Black Ranchhand Bumpers, MBRP 5" Straight Piped Exhaust, Edge Evo, N-fabs, 305/65/18 BFGs on Black Motos, much more soon to come!
(Sold)03 Z71- 33x12 BFG Muds, American Racing Victor Teflons, K&N intake, Gibson Exhaust, Ranchand bumpers, Hypertech programmed, Hella Spots, 12" JL sub, and much more.
z71offroader is offline
post #2 of 9 Old 08-12-2006, 02:39 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
replace the starter.... autozone starters suck, or at least mine does... i get a new one under warranty every year....
carquest seems to be decent.... don't know about advance auto/partsamerica.com though....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 9 Old 08-12-2006, 06:54 AM
bokey
Installed/had several advanced starters; they work great. Only one bad one but it still works (sometimes )
Everything from Autozone sucks - to the max. Buuuut they do have a lifetime warranty but I don't think its worth replacing it once a year. Now, I would never just replace the solenoid, just replace both and see what happens. Also besure you wire is good. IMO, there could be too much current going through your wire causing the solenoid to burn out.
'94 Wrangler - Traded
'87 Trans Am - SOLD
'99 Cherokee Classic
bokey is offline
post #4 of 9 Old 08-12-2006, 07:15 AM Thread Starter
z71offroader
so yall think the starter is killing the solenoid? heard anything about oreilly starters?
post #5 of 9 Old 08-12-2006, 07:31 AM
bokey
possible...
My question is, how come you just replaced the solenoid?
'87 Trans Am - SOLD
bokey is offline
post #6 of 9 Old 08-12-2006, 08:48 AM
ltdanyj
Try bypassing the solenoid and see if it starts. If you still have the same problem, then replace the starter....
ltdanyj is offline
post #7 of 9 Old 08-12-2006, 09:32 PM Thread Starter
z71offroader
i only replaced the solenoid becuase i thought that was the only problem and once i replaced it, it was. but now since its starting to do it again im thinking its something else.
post #8 of 9 Old 08-12-2006, 10:08 PM
Greg Phillips
Greg Phillips's Avatar
just replaced my starter with one from autozone...lifetime warranty...$85.00 for the starter and solenoid...The solenoid by itself was like $80.00...Go Figure!!!
1992 YJ , 2.5L 4 Cyl., 5 Speed Manual Tranny, 2.5" RE Standard, 31 x10.50/15 Bridgestone Dueler H/T's on Stock Wheels...for now!
Greg Phillips is offline
post #9 of 9 Old 08-12-2006, 10:11 PM Thread Starter
z71offroader
my solenoid was only like 15$. is there some sort of an upgraded starter i can get instead of the stock replacement?
Starter Relay or Starter Solenoid questions drespecki YJ Wrangler Technical Forum 7 01-22-2010 09:33 AM
starter solenoid bodiejoe YJ Wrangler Technical Forum 1 09-20-2007 08:30 AM
starter solenoid bodiejoe YJ Wrangler Technical Forum 1 09-20-2007 07:25 AM
Starter or Starter Solenoid problem? Mike in IL TJ Wrangler Technical Forum 5 08-18-2007 11:35 PM
my starter solenoid blew... can i simply replace the solenoid? hmk_21 YJ Wrangler Technical Forum 11 08-30-2006 12:34 PM
