starter running with no key in jeep - JeepForum.com
post #1 of 4 Old 06-24-2011, 11:30 AM Thread Starter
bft89yj
i just replaced my starter last night and everything was working fine i drove it last night and this morning.i went to the auto parts store with the jeep and it was fine but when i drove the mile home and shut it off the starter motor was running. it was not engaged but the motor was spinning. has this happened to any one im not sure what it could be maybe a bad starter or a short some where.
not so stock 89 yj on 35s
bft89yj is offline
post #2 of 4 Old 06-24-2011, 11:37 AM
TheNewbie
Probably a short somewhere. But I think that usually a short will engage the solenoid. I know that if you intentionally put a screwdriver across the 2 starter terminals it will engage the solenoid and jump the starter. So I would guess that it's something in the starter itself. If it's new I'd take it back to the store and tell them you want to exchange it because it's bad.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 4 Old 06-24-2011, 11:39 AM Thread Starter
bft89yj
yeah thats what i was thinking, i figured it would be internal considering it didnt engage the flywheel just spun the motor
bft89yj is offline
post #4 of 4 Old 06-24-2011, 11:53 AM
SpikesHD
1987 YJ Wrangler
I had that happen on a new starter once. I had stopped at home and shut the truck off and the starter motor was spinning. I called the auto parts store and they casually said "just tap the solenoid with a hammer. It'll free up soon" like it happened all the time.
Fact is it did free up, only did that a couple of times.
That was one that had the solenoid on the starter. My heep has the solenoid on the firewall.
SpikesHD is offline
Jeep Starter and Wiring Bac TJ Wrangler Technical Forum 5 01-20-2011 06:14 PM
Jeep won't start, is it my starter? msajeep TJ Wrangler Technical Forum 6 04-13-2010 10:37 AM
Starter turns over with Jeep running MTHughes YJ Wrangler Technical Forum 0 07-20-2009 10:00 AM
Starter keeps turning even after jeep is off xamdarb TJ Wrangler Technical Forum 10 04-02-2009 12:36 PM
Jeep starter Jeep444 TJ Wrangler Technical Forum 7 11-23-2005 08:46 PM
