Starter removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Starter removal
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 10-23-2014, 09:23 AM   #1
Bigverv
Starter removal
Okay guys, frustration level is maxed out right now so I have walked away from it for a bit.
These stupid "external torx" bolts on the starter, any tricks for removal? I bought this set of wrenches, and the 7/16" stripped over it:
http://www.sears.com/craftsman-7-pc-...p-00914018000P
Figuring it might be metric and realizing that I was going to need a socket for the bolt closer to the oil pan anyway, I went and blew money on these sockets, and they still skipped/stripped, when trying both metric and SAE:
http://www.sears.com/craftsman-19pc-...p-00931088000P
at this point, I don't know how many more times I can get away with stripping the tip of the bolt before I need professional assistance. I am in Italy where good tools are hard to come by out in town, and on base the selection is limited. I am lucky to have found the tools that I bought for this.
Is this a torch-heat or PB plaster thing? I have a set of the "bolt outs" but they destroy everything you put them on and I am thinking I will be needing to be reusing theses bolts. New ones, again, will be hard to come by.
Not sure what the hell was so bad about a regular hex head that they couldn't use those, but whatever. I need to get these out so I can get a new starter in.
Please help.
Bigverv is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 09:35 AM   #2
fishadventure
Vice Grips might do it.
Other than that I have hammered a too-small external torx on and done it before. Partly the heavy hits while driving the socket on probably loosens stuff up with the impacts.
I grease up the threads really heavy before reinstalling.
You can also weld a big nut on if they are too bad to drive a socket on.
My current YJ ain't too bad cuz the rocker cover gasket keeps the starter well bathed in oil LOL
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 12:24 PM   #3
Que89YJ
Torch it if you have tried that many times. Do the hammer trick like Fish said. Remove bolt and throw it as far as you can and get a Hex head to replace it.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 12:32 PM   #4
grandboost98
grandboost98's Avatar
Neither link you posted were for external torx.
Heres a sears link for you http://www.sears.com/craftsman-7-pc-...p-00934570000P
If you buy an external torx socket set you should have no problem, that is, if you didnt strip it too much.
Once theyre out, you can replace them with a hex head. I found some in the help section at the parts store
72 Chevy Nova-in progress
98 Pontiac Grand Prix GTP-:SOLD:
http://tiny.cc/BRASSBALLSOFFROAD
grandboost98 is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 01:47 PM   #5
mike134
Definitely use real torx sockets, not universal! I got a good full set of external and internal torx wrenches on amazon (I assume they ship to the little known country of Italy). They are not as nice as the craftsman linked above, but you get the full set: http://www.amazon.com/Anytime-E-Torx...torque+sockets
spare no expense on PB blaster!
Also, torch heat can't hurt. I don't have oxy-acetylene (just low temp propane), so I find it works best for me if I cycle the heat 3 or 4 times. Heat the bolt to as hot as you can get it (if you have propane only), let it cool, pb blaster, tap with hammer, repeat. That should crush the rust on the threads to pieces. if you have oxy-acetylene then just make sure you don't turn it to liquid.
Invest in anti-seize grease so it never happens again!
A lot of vehicles are requiring torx now so it is a good investment. Don't think of it as losing money... think of it as saving slightly less money compared to going to a real mechanic.
mike134 is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 03:09 PM   #6
jason280
No kidding, Torx bits (internal or external) are the one tool you should never skimp on. That being said, I have had good luck using Craftsman universal sockets. But, as its been posted, you will be better off buying a good set of Torx bits for the bolt. Working on Jeeps becomes infinitely easier once you have the right tools!
jason280 is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 06:21 PM   #7
1320yj
There is no such thing as UNIVERSAL sockets or wrenches. If they fit both they don't fit either right.
Torx sockets both internal and external and tamper proof are very specific nothing else will work properly.
Spend the money and buy quality sockets cheap ones will only round out the fasteners causing more grief than if you would have spent a few more bucks. After all you have a Jeep you will be using them a lot in the future.
1995 2.5 5Speed SOA 33x12.50 Mud Rovers
1320yj is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 07:01 PM   #8
pasinbuy
I beg to differ there is one universal wrench. It is a Crescent Wrench. Sorry to correct you. LOL
Anyway ditto on what 1320 says. Buy a good set of metric and SAE wrenches and try not to bust your knuckles. Although true some Metric sizes are the same as SAE you do run the risk of rounding the nuts and bolts experimenting.
pasinbuy is offline   Reply With Quote Quick reply to this message
Unread 10-24-2014, 11:43 AM   #9
Bigverv
Thanks for all the input y'all. Skimping on the tools wasn't my intention, just got the closest thing that was available, since we have limited selection. I'll get either the craftsman or amazon set online and just wait a bit till they get here, so it can be done right. That means I am on Jeep time-out for another couple of weeks!
Unread 10-24-2014, 11:50 AM   #10
mike134
You can always bump start!
You're going to replace the starter anyway... So see if hitting it with a hammer gets it operational enough to drive your jeep
