Starter Relay Wiring - Ground Wire Question - JeepForum.com
post #1 of 5 Old 03-05-2009, 11:02 PM Thread Starter
DocArt
My 1988 4.2L wrangler received a new starter relay. The new relay had a wire terminal labeled "ground" (lower right terminal).
When I removed the old starter relay, this terminal ("ground") wire went to a multi-wire connector under the Jeep, near the tranmission and toward the back. I was wondering if this is a ground wire, or should I just make a new ground wire for this terminal. Could use some advice on this... Is this the usual connection for the ground terminal on the starter relay ?
DocArt is offline
post #2 of 5 Old 03-06-2009, 04:46 AM
ctm
that ground on the relay goes to the multi-pin connector that deals with backup lamps and/or neutral safety switch depending on what transmission.
For 4.2L auto it goes to the neutral safety switch so that you can only start in P or N.
with a 4.2L and manual tranny that wire is just ends up connected to other ground wires.
So if you have manual it's just a ground wire. Feel free to connect it to a better ground location.
ctm is offline
post #3 of 5 Old 03-06-2009, 05:16 PM Thread Starter
DocArt
THANK YOU CTM, Appreciate your input.
DocArt is offline
post #4 of 5 Old 03-06-2009, 06:39 PM
jay-h
You can never have too many ground points.
jay-h is offline
post #5 of 5 Old 03-06-2009, 06:41 PM
jay-h
On my old chevy, I found out that under some loads the body was floating about 1V above the engine ground. Fixed that and headlights and accessories worked much better.
jay-h is offline
Need Help with Starter Relay Wiring WarPony YJ Wrangler Technical Forum 22 12-02-2013 06:33 AM
88 YJ starter relay wiring diagram brianOU YJ Wrangler Technical Forum 5 01-30-2012 09:48 PM
95' yj starter relay wiring diagram jws1961 YJ Wrangler Technical Forum 3 03-26-2008 06:29 PM
Starter relay wire jeepfury YJ Wrangler Technical Forum 3 10-14-2006 10:31 AM
88 Wrangler Starter Relay Wiring alex88 YJ Wrangler Technical Forum 2 07-20-2004 08:52 PM
