starter relay melting wires??? - JeepForum.com
post #1 of 21 Old 05-07-2007, 09:46 PM Thread Starter
t_rexx70
t_rexx70's Avatar
I've got an 88 wrangler that killed on me today..wouldn't restart...smelled electrical short smell. Found wires coming out of the starter relay that were melted and several others were hot as hell. I'm replacing it tomorrow, but has anyone else had this problem. I'm assuming that the part is just bad/worn out. It's only 20 years old so go figure. Just wondering if anyone else has had this problem and why a fuse didn't prevent this from happening????
88YJ 4.2l, weber 32/36, nuttered, 4" super lift, TFI, stock 30 and 35 pos axles alloy 4.10's, lockrights, posilocked, 33 X 12.50 Mudbrutes
t_rexx70 is offline
post #2 of 21 Old 05-08-2007, 09:00 AM
Austin_YJ
1987 YJ Wrangler
The '88s have fusable links (green on mine) at the starter relay. Those take the place of fuses. Something is shorting out if those are getting hot and melting.
'87 YJ, 4.2L, MC2100, HEI, RE 4.5", 2" body lift, ford 8.8 locked, 36" Swampers, homemade discos, Superwinch x9
Austin_YJ is offline
post #3 of 21 Old 05-08-2007, 09:04 AM
dunno513
resistance = heat.
Replace it and drive on.
Fuses only protect from electrical surges.
make sure all connections are clean and tight. loose connections can create the initial resistance, as can deteriorated wire.
dunno513 is offline
post #4 of 21 Old 05-08-2007, 11:38 AM Thread Starter
t_rexx70
t_rexx70's Avatar
Thanks guys....it is definitely the starter relay....at some point it went out causing the battery to be overcharged by the alternator which caused too much electricity. Also, the dimwit that owned the vehicle before me used freakin duct tape to join some of the wires. I believe this was definitely a contributing factor to the heat. So in the end it was multiple things. Just glad I found it out before I was cruising down the interstate doing 70 and the damned thing just died. God was watching over me this go around.......
t_rexx70 is offline
post #5 of 21 Old 05-08-2007, 11:42 AM Thread Starter
t_rexx70
t_rexx70's Avatar
Thanks for the info. on the fuseable link too. I figured that is what it was but you confirmed that for me. I'm going to cut out all the bad wires and replace and put new fuseable links on the proper ones. Those starter relays are kinda hard to come by. O'reilly's had to order it. Carquest had them but cost $20 more. Just FYI in case someone needs one in the future. I believe it has been causing my electrical system to do weird things. Hopefully this will straighten some of that out. Looking at doing all new wires down the road......Probably take a year off of my life in the process
t_rexx70 is offline
post #6 of 21 Old 05-08-2007, 11:49 AM
Austin_YJ
1987 YJ Wrangler
If you haven't already ordered one, I've got an extra starter relay laying in my shop.
post #7 of 21 Old 05-08-2007, 02:03 PM Thread Starter
t_rexx70
t_rexx70's Avatar
Man I really appreciate that...I ordered it yesterday and I'm picking it up in the morning. That way too I'll have a warranty...but I really do appreciate the offer. You better hold on to it anyway. You never know if you might need it. Have you ever had to change your's so far??
t_rexx70 is offline
post #8 of 21 Old 05-08-2007, 02:21 PM
Austin_YJ
1987 YJ Wrangler
I had to change the whole wiring harness because I burt one wire that melted several others. I have an '87 so the relay is a little different than the one I got with the new harness.
post #9 of 21 Old 05-08-2007, 05:48 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
the starter relay has nothing to do with your charging system. the voltage regulator is built into your alternator most likely. only thing the starter relay coudl do is prohibit the alternator from charging anything if you had a bad connection at that big lug on top of the relay.
it's a dealer available part for about $35, but it's pretty universal. i got one on eBay for a buick for about $7 shipped if i remember right... brand new in the box.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #10 of 21 Old 05-16-2007, 11:47 PM Thread Starter
t_rexx70
t_rexx70's Avatar
Well I'll tell ya like this big and broke...it was melting wires...I changed it and no more melting wires....don't know what else to say homey....
t_rexx70 is offline
post #11 of 21 Old 05-17-2007, 12:02 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
melting wires doesn't mean overcharging "homey"
melting wires means you have a short.
glad you got it fixed. hopefully you've learned how the starter relay works and fully understand what fusible links are and how they function to protect the rest of your wiring.....
-Erik
post #12 of 21 Old 05-17-2007, 12:19 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
erik my homey...
there is a time to give up, and me feels like this is the time.....so peace out homey and chill......
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #13 of 21 Old 05-17-2007, 12:24 AM
timatoe
timatoe's Avatar
The only thing I have to add for da homies,,,,is that dimwit that did the duct tape thing was the factory.
Believe it or not????
timatoe is offline
post #14 of 21 Old 05-17-2007, 12:42 AM Thread Starter
t_rexx70
t_rexx70's Avatar
erik me homey...the starter relay was shorted on the inside....I know you are an ace mechanic and everything but it was actually opened and the short was on the inside...and the fuseable links were in place....so that's the deal homey...peace out!
t_rexx70 is offline
post #15 of 21 Old 05-17-2007, 12:48 AM Thread Starter
t_rexx70
t_rexx70's Avatar
No **** on the duct tape!!!! That came from the factory like that!!!!! Fa Sho dimwits!
t_rexx70 is offline
burning wires at starter relay markmyst YJ Wrangler Technical Forum 16 04-03-2010 02:28 PM
Starter Relay or Starter Solenoid questions drespecki YJ Wrangler Technical Forum 7 01-22-2010 10:33 AM
Is it the starter or the relay? Gadsal YJ Wrangler Technical Forum 4 06-10-2009 10:22 AM
starter relay newYJfan YJ Wrangler Technical Forum 2 05-27-2008 06:21 PM
Horn not working......not wires, fuse or relay. luv2hmr TJ Wrangler Technical Forum 12 04-12-2006 04:33 PM
