Starter Problems...HELP!! - JeepForum.com
post #1 of 12 Old 12-14-2003, 05:07 PM Thread Starter
Maine-yj
Hey guys,
I have a problem, over the past week my starter, or something with the ignition system has been giving me fits...Sometimes it will start right up...other times it will click a few time and then start up or other time it will click click click click and keep on clicking, not the kind of clicking like the solenoid clicking but somthing else. So today i went and replaced the starter...it then started right up...So a few minutes ago i went to start her and all i got was those damn clicks...Oh and other times before i replaced the starter she would just turn and turn and turn but never start. Please help!
1992 Wrangler Sahara 4.0
3.5 BDS, 33X10.50 BFG AT
Herculined Tub
9000lb superwinch, Magnaflow catback
D44 rear with Electrac and TruTrac up front
Jeep Score: 235
Maine-yj is offline
post #2 of 12 Old 12-14-2003, 05:39 PM
Silver yj
Originally Posted by Maine-yj
Hey guys,
Still could be the starter.Did u have a shim with it?Also if its a NAPA Starter they suck.
Silver yj is offline
post #3 of 12 Old 12-14-2003, 05:58 PM Thread Starter
Maine-yj
The starter is some 70 dollar job from autozone, a rebuild, but i dont know man, it started the first time, then bout 10 minutes later it didnt it only sounding like it was grinding against the flywheel(sounds like click click click really fast) what could it be. I inspected the flywheel but im not sure what i should look for there wasnt anything obvious...HELP!
Herculined Tub
Jeep Score: 235
Maine-yj is offline
post #4 of 12 Old 12-14-2003, 06:26 PM Thread Starter
Maine-yj
Honestly what would a bad flywheel look like, i mean would it be obvious, because honestly the flywheel looks fine, i was reading somewhere, dunno where,(ive been searching like a mad man for a solution) that it still could be an electrical problem, either theres not enough charge coming to the solenoid. Ive nearly killed the battery this week on several occasions, but she still seems to start, sounds like i got enough juice...and like i said about sometimes it would sound like its grinding and then other times it would roll and roll and roll but never turn over. And when it rolled there seemed to be plenty of juice... so i dunno, this is confusing me, can anyone help?
Herculined Tub
Jeep Score: 235
Maine-yj is offline
post #5 of 12 Old 12-15-2003, 11:47 PM
sturgman
Get under the jeep and smack your starter with a hammer.,This works best while someone is turning the ignition but also will work with a few good pokes and then try to start it yourself.I had to do this with my last starter until i changed it.Works like a charm!! Like buddy says, maybe you gota bum deal on your rebuilt?
sturgman is offline
post #6 of 12 Old 12-16-2003, 12:20 AM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
I've went through at least 6 starters in a year because of junk rebuilds.
Devious is offline
post #7 of 12 Old 12-16-2003, 08:03 PM
DevilDogJeep
DevilDogJeep's Avatar
Hey don't worry about the flywheel it sounds like a starter problem again. But if you had a bad flywheel you would know it. It makes a God awful noise when it is missing some teeth. The only other thing I've ever seen go bad on a flywheel is: one that broke in the middle where it bolts to the engine, so the flywheel would spin and nothing else would happen. Just letting you know what to look for.
DevilDogJeep is offline
post #8 of 12 Old 12-16-2003, 08:19 PM
Bigbluejeep
Junior Member
I purchased a starter from autozone after a similar problem with my ole nissan. I removed the starter in there parking lot and they tested it and, from there test a good starter. This was after replacing and tracing every wire, relay and battery in sight. Finally convinced them by saying if you give me another starter and if it still does the same thing I'll buy it and take your word that something else is wrong. Guess what it was there starter, and the nice manager at the Autozone gave me a full refund after all I had spent, except the battery(i couldn't find the reciept). So new relays, starter, and battery only cost me 49.00.
I wish you luck but would try replacing the starter again. took me 3 tries to get a good one but was worth it in the end.(no more push starting)
89 Yj 6cyl
Weber
4" Lift
Welded Tow Hooks Front & Rear
Soft Top (hard top got lost in a rollover)
KC Daylighters
55 watt running lights mounted in Frame for Night Rockin
33/12.50/15 Buckshot Mudders
Rear Lock-rite (best mod ever!)
Detroit Front Locker
Flowmaster
2" BL
Bigbluejeep is offline
post #9 of 12 Old 12-16-2003, 08:25 PM
alilredjeep
alilredjeep's Avatar
Hey guys,
Check your battery terminal connections and clean them real good.
Starters take a lot of juice and if the battery connection is corroded.....the starters not getting the full power it needs.
Wet weather will make the problem worse.
But then if its spinning over pretty good.....could be something else.
alilredjeep
Eddie
RED JEEP CLUB MEMBER #92
'92 WRANGLER, 2.5 Litre, 5 Speed, Rag Top, Superwinch LP8500, Cepek 130W Driving Lights, 31x10.50/AT with no lift, Of course! It rubs!
alilredjeep is offline
post #10 of 12 Old 12-17-2003, 07:06 AM
drew2000
drew2000's Avatar
Did you replace the cables going to and from your starter? These are often overlooked and can fail over time, I second the suggestion of cleaning the battery terminals. You can also buy an anti-corrosion gel from Pep Boys, etc, for the terminals.
Drew
alilredjeep
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #11 of 12 Old 07-27-2011, 01:33 PM
cagaito
I have the same issue, but mine make awful noise mostly upon start. What can be?
cagaito is offline
post #12 of 12 Old 07-27-2011, 04:45 PM
monkeyhouse
Drew
Agree with these two posts 100%. Check all connections and cables, especially grounds. You can have a brand new battery and starter, but with poor connections, all of that does no good at all.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 10:22 AM
2.5 Starter Problems Tradewinds YJ Wrangler Technical Forum 1 07-16-2009 04:48 PM
Starter problems kimvansa YJ Wrangler Technical Forum 1 03-25-2006 10:55 AM
starter problems? lsufanjeeper TJ Wrangler Technical Forum 1 02-27-2005 12:03 PM
Starter problems I94yj YJ Wrangler Technical Forum 4 12-23-2002 04:01 PM
