Starter problems - JeepForum.com
post #1 of 9 Old 11-21-2007, 10:10 AM Thread Starter
sammar
Starter problems
Hey All,
Yesterday I came home from work my 95 YJ was fine. I went to go out to the store and it wouldnt turn over at all. Something with the starter. if i jump start it it runs fine. when i turn the key to start it absolutley nothing happens. Any Ideas?
Thanks
sammar is offline
post #2 of 9 Old 11-21-2007, 10:16 AM
giggityjeeper
buy a new starter 2 bolts.....on .... off done
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #3 of 9 Old 11-21-2007, 10:18 AM Thread Starter
sammar
I was looking in the Haynes manual it said sometimes u have to remove the exaust
sammar is offline
post #4 of 9 Old 11-21-2007, 11:04 AM
giggityjeeper
nope its tight but nope......just do it when its cold so you dot burn yourself.....and I found from the top is easier, but climb under its not hard to get at....well mine is a 90 but I would think it would be similar........
post #5 of 9 Old 11-21-2007, 11:10 AM Thread Starter
sammar
Cool thanks but I have the Haynes Manual and it dosent say where the starter is located on the engine. lol i know stupid but i am new to this
sammar is offline
post #6 of 9 Old 11-21-2007, 11:25 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
FIRST thing you should do is check your batt connections because if you can jump it, you may not have a bad starter. It could be the batt and wires.
As for the starter location.
Bottom of the engine, to the pass side of the oil pan. Here is a link with some pics, It is a TJ but same location . DO NOT follow those instructions for the mount is different. Your literally looking at 2 bolts and it's out.
You can at least take it out and have it tested.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 9 Old 11-21-2007, 12:11 PM Thread Starter
sammar
i checked connections seems fine. hooked 12 volts to starter and it barely turned seemd to be siezed
sammar is offline
post #8 of 9 Old 11-21-2007, 03:49 PM
Jeep25
Originally Posted by sammar
Hey All,
Thanks
Does it only start "when" the check engine light is on?
Jeep25 is offline
post #9 of 9 Old 11-22-2007, 09:25 AM Thread Starter
sammar
Check Engine light never came on. It was the starter. I replaced it and all is working fine now. Thanks for all your help.
sammar is offline
Starter Problems...HELP!! Maine-yj YJ Wrangler Technical Forum 11 07-27-2011 03:45 PM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
2.5 Starter Problems Tradewinds YJ Wrangler Technical Forum 1 07-16-2009 03:48 PM
Starter problems KBwithaJEEP YJ Wrangler Technical Forum 5 09-18-2006 04:34 PM
Starter problems Mdmann YJ Wrangler Technical Forum 2 02-02-2005 10:45 AM
