starter problems!! - JeepForum.com
post #1 of 26 Old 12-18-2013, 12:35 PM Thread Starter
ajstarr2288
starter problems!!
so, I replaced my starter over the weekend, worked fine. Monday shut the jeep off, went to turn back on and nothing. got it bump started to get home. Today I took the starter out, brought it to parts store and it passed. so I reinstalled it, still nothing. hooked jumper cables up to see if the battery was low. my relay makes a click when I attempt to turn engine over. but the starter makes no noise. I felt the solenoid and it was getting warm. any one have any help available?
95 yj 2.5l.
"Thrash it dont Trash it"
ajstarr2288 is offline
post #2 of 26 Old 12-18-2013, 01:07 PM
Peety
Not to overstate the obvious, have you checked the battery cables for corrosion and voltage drop ?
http://www.freeasestudyguides.com/vo...drop-test.html
Peety is offline
post #3 of 26 Old 12-18-2013, 06:03 PM
Louie4
"You pass butter"
Louie4's Avatar
Also check your grounds. There is one on the block, the body and various others mixed in.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #4 of 26 Old 12-18-2013, 06:08 PM
superj
If your relay only clicks, I would charge the battery
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #5 of 26 Old 12-19-2013, 04:33 PM Thread Starter
ajstarr2288
so today I checked my grounds, cant find a bad one, I tapped the starter with a hammer and used a screwdriver on the solenoid and it rapidly clicked. then nothing, tapped it again and it clicks.
95 yj 2.5l.
post #6 of 26 Old 12-19-2013, 04:40 PM
superj
Charge the battery
superj is offline
post #7 of 26 Old 12-19-2013, 04:42 PM
lespaul_custom
I had the same issue last year. my problem ended up being the ignition switch. have someone check for power at the starter while you turn the switch
originally posted by urb4ntroll
The weird thing is that I thought I hear a minor bang, almost like a fart sound coming out of my Jeep, but I'm not sure what it was. It has never happened before the glue incident.
white jeep club #1993 looking to buy complete rear seat belts
lespaul_custom is offline
post #8 of 26 Old 12-19-2013, 04:49 PM
dancytron
Assuming you charged the battery, then bad battery cables or bad connections.
You might try to just replace the ends near the battery.
dancytron is online now
post #9 of 26 Old 12-19-2013, 05:22 PM
Que89YJ
x2 with Dancytron and Peety. You have a bad wire. Use jumper cables and try jumpering across power and ground directly to the starter. The battery ground is every bit as important as the positive and corrosion is not always visible. Clean connections. All the connections.
Que89YJ is online now
post #10 of 26 Old 12-20-2013, 07:17 AM
Peety
For my second overstatement of the obvoius:
Is the battery any good ?
Peety is offline
post #11 of 26 Old 12-20-2013, 04:01 PM Thread Starter
ajstarr2288
so today brought my battery to interstate batteries and had them test it. Passed with no issues, put it back in and nothing still. my headlights do not dim when I try to start. tried making a ground with jumper cables and that didn't do anything. I am lost!!!
95 yj 2.5l.
post #12 of 26 Old 12-20-2013, 04:15 PM
Que89YJ
Does the starter relay click when you turn the key?
Fault codes:
Mean Max pics of everything:
No Start:
post #13 of 26 Old 12-21-2013, 09:18 AM
fishadventure
have someone turn the key to 'start' while you check the feed to the solenoid for voltage when the key is turned. If you have voltage sending to the solenoid and starter checks out good, then you may just need to repair or buy new battery cables. You can check for voltage at the big wire feeding the solenoid and then for voltage /after/ the solenoid when the key is operated, but you might be fooled- a bad battery cable might show voltage but not pass enough amps to crank the engine.
I would put my money on cables or new cable ends.
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline
post #14 of 26 Old 12-22-2013, 10:40 AM Thread Starter
ajstarr2288
I get 12 v at the ignition switch wire on the solenoid all the time
95 yj 2.5l.
post #15 of 26 Old 12-22-2013, 01:45 PM
Que89YJ
Ok so the relay clicks...I should read everything before I post. Make sure you are in neutral and on the starter relay on the pdc use a 3" piece of wire and with the trans in neutral remove the relay and jump pin 30/87 in the relay socket. The pin diagram is on the side of the relay. This is just lime turning the key. Post if it starts.
Fault codes:
No Start:
