Starter problems - JeepForum.com
post #1 of 5 Old 12-18-2011, 04:48 PM Thread Starter
YJMCB
1987 YJ Wrangler
Starter problems
Any advice on how to best shield my starter from header heat on my 350 chevy YJ? Going thru starters about every 12-16 months.Even had a shop shim one because i thought I wasn't getting it right.Looked at some of the wraps that be be bought to be put on starter,wondered how these hold up?Any ideas greatly appreciated,thanks yjmcb
87 YJ,SOA,35-12.50 Mickey Thompson Claws 92 XJ,8.8 detroit rear,35's & other stuff.
YJMCB is offline
post #2 of 5 Old 12-18-2011, 04:54 PM
1SASjeepster
I had a 1986 Chevy Astro van with a 4.3 V6. I used a metallic insulated "cloth" type heat shield which held in place by two stainless steel straps. This worked for me and I never had to change the starter. In the Astro van, the passenger side exhaust manifold IS A TUBE HEADER. It gets super hot in vans but the shield worked. If it didn't, I planned on putting in a metal shield also that went over the starter. As noted, I didn't need it. I can't promise this will work for you, but it did for me. I bought the "kit" from Summit but I don't know what the name was and this was twenty years ago.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #3 of 5 Old 12-18-2011, 05:36 PM
oldtime_ironman
Very common prob on chevy V- engines. For years they've made metal heat shields that bolt-on to the starter for about $30, or use header wrap as noted. Summit racing would have all that, and in fact even the GM performance catalog has it.
oldtime_ironman is offline
post #4 of 5 Old 12-18-2011, 06:16 PM
ROWA
ROWA's Avatar
You might need to wrap your headers, this will reduce the radiated heat significantly. Check on summit racing for their header wrap.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #5 of 5 Old 12-18-2011, 07:14 PM Thread Starter
YJMCB
1987 YJ Wrangler
I had been wondering about the durability of some type of starter wrap,this is what I will probably try,thanksyjmcb
YJMCB is offline
Starter Solenoid or Starter Motor Problems hjlueth0001 TJ Wrangler Technical Forum 4 10-20-2011 09:50 PM
starter problems mel454 JK Wrangler Technical Forum 2 08-07-2010 08:40 AM
Starter Problems? Deserteagle2 YJ Wrangler Technical Forum 6 08-03-2010 11:41 AM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
Starter problems kimvansa YJ Wrangler Technical Forum 1 03-25-2006 09:55 AM
