starter problems - JeepForum.com
post #1 of 21 Old 10-05-2010, 07:28 PM Thread Starter
pajeepfreak
starter problems
I have a 4.2 motor that I swapped out the pugeot trans for the AX15 I put everything back together and went to start it and the starter just free spins like it is too short now in the AX15 bellhousing to mesh with the flywheel. I have the external style clutch bellhousing in there now and the starter is the pugeot original one. Are the starters different lengths between the pugeot and the AX15 and are they different between the internal and external AX15s? Just want to make sure I order the right starter.
pajeepfreak is offline
post #2 of 21 Old 10-05-2010, 08:37 PM
Xtremjeep
Sounds like your starter is not kicking out the gear, and just spinning. As far as I know the starters are the same. I used my stock one after installing the ax-15.
Build Thread:
1980 CJ-7 Mall crawler (RIP 2010)
1983 CJ-8 Scrambler Full resto in progress
1988 YJ Fully Built but never Done
Xtremjeep is offline
post #3 of 21 Old 10-05-2010, 09:36 PM
88blkyj
hmm weird I kept the stock starter on mine too...check to see if its bolted up right?
88blkyj is offline
post #4 of 21 Old 10-05-2010, 10:50 PM
MJMPC
Make sure it isnt wired backwards.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 21 Old 10-06-2010, 04:02 AM
dodger889
How do you wire a starter up backwards??? There is a hot lead from the battery and one wire to the solenoid. They only fit one way. Since OP said it spins that would tell me it wired correctly.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 21 Old 10-06-2010, 07:26 AM
Dado99TJ
Junior Member
Dado99TJ's Avatar
Is the nose of the starter too short or is the starter drive now too far away (laterally) from the flywheel to engage? Not sure with the AX-15 setup, but you may need to get the starter closer to the flywheel by "slotting" or making your bolt holes oblong.
Nightcrew member #331
Blue Jeep Club member #332
Dado99TJ is offline
post #7 of 21 Old 10-06-2010, 07:39 AM Thread Starter
pajeepfreak
This isin a CJ7 but I figured you guys would know better cause it is stock in yours. I kept the CJ starter solenoid on on the firewall cause it was wired up and new and then on the YJ starter a took off the main wire to the solenoid and then connected it to the one wire setup of the CJ solenoid. That might be my problem but I dont know too much about the YJ starters. Any ideas of how I can wire this up to work? Wiring diagrams would be great if you guys have any.
post #8 of 21 Old 10-06-2010, 08:19 AM
zeus87gn
1987 YJ Wrangler
It's got to be the difference in the later model bell housing with the external slave. I have the AX15 but stuck with the internal slave. That early model bell housing was still attached to the trani when I got it. I am using my 87 starter and don't have a problem.
But if I don't mount it right, it won't engage properly and grind on the ring gear. I have to get the bolts right at finger tight and push it towards the engine block then tighten the bolts.
My 92 has the internal slave but has the gear reduction starter. It mounts the same way, but there may be something different i'm not aware of.
Z
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #9 of 21 Old 10-18-2010, 12:08 PM Thread Starter
pajeepfreak
any more ideas? someone has to have had this problem before?
post #10 of 21 Old 10-18-2010, 12:53 PM
monkeyhouse
I swear there was a link about this before, the cj starters are different if I am remembering correctlly. I think it was fernando maybe who posted with this problem? Keep in mind, my memory isn't what it used to be, but I don't think if you are going from a starter/solenoid combo to split up assebly or viceversa, it won't work that way. I'll do a search and see if I can find the link...my luck it was a totally different user and problem, lol.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #11 of 21 Old 10-18-2010, 01:02 PM
monkeyhouse
Try this link, there is some info that might help:
http://www.jeepforum.com/forum/f12/8...blems-1001387/
post #12 of 21 Old 10-18-2010, 01:40 PM
cwjeep
there is 2 different starters. the old style large starter and the new style small starter. they are different lengths.
cwjeep is offline
post #13 of 21 Old 10-18-2010, 01:41 PM
cwjeep
the old style starter motor is about 5 in. around. the new style is about 3 in. around.
cwjeep is offline
post #14 of 21 Old 10-18-2010, 01:46 PM
cwjeep
the difference is that one is closer to the fly wheel than the other. i had to change mine when i changed trans.
cwjeep is offline
post #15 of 21 Old 10-18-2010, 01:50 PM
Douglas S.
I run an external slave ax-15 and I used the stock starter (CJ style with solenoid on firewall). No problems at all.
1991 Land Cruiser HDJ81
Douglas S. is offline
Starter Problems...HELP!! Maine-yj YJ Wrangler Technical Forum 11 07-27-2011 03:45 PM
starter problems again :x CALUfootball64 YJ Wrangler Technical Forum 9 03-22-2010 02:23 PM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
Starter Problems? Famous337 TJ Wrangler Technical Forum 5 12-08-2008 06:34 PM
Starter problems sammar YJ Wrangler Technical Forum 8 11-22-2007 09:25 AM
