Starter Problems? - JeepForum.com
post #1 of 7 Old 08-02-2010, 06:23 PM Thread Starter
Deserteagle2
Starter Problems?
My Jeep is cranking over slowly and sometimes won't start. I put a new battery in and that did not help. Once it starts it runs fine. Is the problem the starter or what else could it be?
Deserteagle2 is offline
post #2 of 7 Old 08-02-2010, 07:07 PM
idaholtby
Check your cables. This problem screams of a bad cable. You can test this by bypassing the cable from the battery to the starter with a jumper cable. Also jumper the battery negative to chassis ground. If it fires right up, then you proved the OEM Cable(s) is/are toast. These commonly become corroded within the shielding, and otherwise appear to be good. Corrosion can grow below the insulation and impede the current flow required to start the engine.
idaholtby is offline
post #3 of 7 Old 08-02-2010, 09:15 PM Thread Starter
Deserteagle2
Ok I will check that, my cables are original I think.
post #4 of 7 Old 08-02-2010, 10:44 PM
Shalayko94
Check your ground straps too, especially the strap from the firewall to block.
Shalayko94 is offline
post #5 of 7 Old 08-03-2010, 06:55 AM
sloan74
Same symptoms my starter had before it failed all together. Sounds like the motor on it is going out.
Run a volt-meter check from the positive and negative nodes of the starter. That will tell you if it's a bad ground/cable or a bad starter.
With the key on, if your getting 12 volts at the starter then your starter is on it's way out the door....
It's very easy to replace. Be sure to take it off first before going to the parts store so you get the core discount. I paid 60 bucks for mine at Autozone. But the Autozone rebuilds are pretty crappy. If you can let the jeep sit for a few days maybe order a good one from Napa or something.
You will need a 3/8 in. drive star socket to remove the bolts. I purchased a small set at Autozone and it had the correct size. You have to remove one of the bellhousing inspection plate bolts also but that one is a standard. Tap your socket driver up nice and tight with a rubber mallet before you losen the 2 starter bolts. You do NOT want to strip those or you will turn a easy starter swap into a nightmare...lol
sloan74 is offline
post #6 of 7 Old 08-03-2010, 11:22 AM
T-Mack
my starter was doing the same befor it crapped out on me. took mine to checker and even though it passed it was verry verry week. got a new starter and problem solved.
T-Mack is offline
post #7 of 7 Old 08-03-2010, 11:41 AM
pasinbuy
Before pulling your starter it is important to disconnect your battery.
You probably knew that. The one time I forgot, wow what a mess. Scary too.
pasinbuy is offline
'87 YJ Starter Problems boit12 YJ Wrangler Technical Forum 30 09-04-2014 08:01 AM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
starter problems?!?!?!! flipper1 Wrangler General Discussion 2 07-18-2008 06:47 PM
Starter problems Mdmann YJ Wrangler Technical Forum 2 02-02-2005 10:45 AM
Starter problems I94yj YJ Wrangler Technical Forum 4 12-23-2002 03:01 PM
