Starter intstallation - JeepForum.com
post #1 of 6 Old 02-06-2002, 04:52 PM Thread Starter
grantnps
I figured out what the squeeling noise is taday. It's my starter. The place I went to says 300 for parts and labor. I can get a starter motor for around 160. Is it hard to put in a new starter, or should I have them do it?
Thanks for the help.
Grant
'94 YJ 4 banger :( 4" ProComp suspension 32x12.5 a/t's, flow's, kn air filter charger, and lots of little appearance mods.
grantnps is offline
post #2 of 6 Old 02-06-2002, 04:55 PM
Bob K
Bob K's Avatar
Very easy. Disconnect battery. Disconnect starter cable to starter. Remove two mounting bolts. Mount new starter.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 6 Old 02-06-2002, 05:10 PM Thread Starter
grantnps
The guy said "the starter", is the starter motor what he means, or could be it something else. It was over 200 and the starter motor is the only thing remotely close to that at quadratec.com...so I'm guessing what that means. I just don't want to spend the money, and him be talking about something else.
grantnps is offline
post #4 of 6 Old 02-06-2002, 05:16 PM Thread Starter
grantnps
Oh, and also, where is the starter located. Thanks
grantnps is offline
post #5 of 6 Old 02-06-2002, 08:27 PM
Joker2002
Crawl under your Jeep and look right where the tranny bolts up to the engine. On the passenger side, you should see the starter mounted to the tranny. That's the way it is on mine, at least. I'd guess it'd be the same on yours. If not, just crawl around and look, they're hard to miss.
Blake
2000 TJ/4.0 - Stock, but that will change!
Joker2002 is offline
post #6 of 6 Old 02-06-2002, 09:10 PM Thread Starter
grantnps
Found it and got it replaced for around $100 instead of $300.
Fixed the problem and is running better than ever.
Thanks for all the help, I really appriciate it.
Grant
grantnps is offline
Starter Relay or Starter Solenoid questions drespecki YJ Wrangler Technical Forum 7 01-22-2010 10:33 AM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 10:22 AM
whats the diffrence between a tj starter and a xj starter sameolsong TJ Wrangler Technical Forum 1 09-05-2009 10:08 AM
Starter or Starter Solenoid problem? Mike in IL TJ Wrangler Technical Forum 5 08-19-2007 12:35 AM
Cold starter Vs. Hot starter issues Dugrite YJ Wrangler Technical Forum 6 07-27-2007 08:49 AM
