starter help! - JeepForum.com
post #1 of 6 Old 10-29-2013, 10:42 AM Thread Starter
mikes95YJ
starter help!
i was told to look and see if my 95 yjs starter needed a shim or not. it had been making a strange noise when i first fired it up for awhile. went to start it this morning and got nothing but horrible grinding noises. what should i do? just buy a new starter? please any suggestions asap. thansk
mikes95YJ is offline
post #2 of 6 Old 10-29-2013, 10:55 AM
Que89YJ
Grinding noise=bad starter or damaged flywheel. Pull it and inspect the teeth, replace the starter. Shim if necessary.
Que89YJ is online now
post #3 of 6 Old 10-29-2013, 12:57 PM Thread Starter
mikes95YJ
so i should just get a new starter regardless? and inspect the old one
post #4 of 6 Old 10-29-2013, 02:16 PM
Que89YJ
Inspect your flywheel when you take the starter out. Yes, replace it.
Fault codes:
Mean Max pics of everything:
No Start:
post #5 of 6 Old 10-29-2013, 02:28 PM
Apollo12227
To add to Que's statement...
To make it easier to inspect the flywheel. Leave the starter on but remove the dust cover so you can see the flywheel that the starter turns... Then remove the center wire on the distributer comming from the coil (so the engine will not start, but will still turn over). Then you can have someone crank the motor while you are underneith the jeep, you can watch the flywheel turn while your friend is cranking the motor. Checked for chipped, missing, or damaged teeth.
Apollo12227 is offline
post #6 of 6 Old 10-30-2013, 06:50 AM Thread Starter
mikes95YJ
sounds good! thanks for the help
