Starter drag - JeepForum.com
post #1 of 4 Old 07-14-2012, 11:57 AM Thread Starter
jeep108
Starter drag
I'll try to keep this short and to the point...
When i start my jeep the starter drags especially if its warmed up. I've replaced the battery, starter and battery cable ends.
I disconnected the wire from the starter to the ignition switch and ran a jumper from the 12v switched post on the starter directly to the battery.
With the ignition key in the off position, when i touch the jumper wire to the battery it turns over easily and all day long.
With the ignition key moved to the on position, when i touch the jumper wire to the battery it drags down again.
Any ideas?
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #2 of 4 Old 07-14-2012, 12:10 PM
yoyoyo109
2015 JK Wrangler
when the ignition is switched to start (not on, off or accessory) all power from the car is cut and the battery is solely powering the starter. thats why starting a car turns off the radio for example. power is diverted to start the car. that would explain why it is dragging down when the car is switched to on
has it ever not started or left you stranded until you kept turning the ignition?
yoyoyo109 is offline
post #3 of 4 Old 07-14-2012, 04:04 PM Thread Starter
jeep108
I don't think I described my problem very well - when I say drag I mean it really drags like its not going to start, sometimes I have to let off the key and try several times before it does start. Sometimes it makes an awful binding noise as well but again doesn't do it when I jump the 12v switched post straight to the battery with the ignition off
jeep108 is offline
post #4 of 4 Old 07-14-2012, 04:10 PM Thread Starter
jeep108
Yoyoyo109 after rereading your post I get what your saying but me using the jumper wire is an attempt at diagnosing what is causing it to drag under normal starting procedures
jeep108 is offline
After removing transmission/starter, starter now squeals. FrontRightTIRE TJ Wrangler Technical Forum 1 06-19-2012 10:38 PM
Starter Solenoid or Starter Motor Problems hjlueth0001 TJ Wrangler Technical Forum 4 10-20-2011 09:50 PM
Starter Relay or Starter Solenoid questions drespecki YJ Wrangler Technical Forum 7 01-22-2010 09:33 AM
Starter or Starter Solenoid problem? Mike in IL TJ Wrangler Technical Forum 5 08-18-2007 11:35 PM
Starter drag. glm 87 wrangler YJ Wrangler Technical Forum 5 12-13-2001 05:59 PM
