Started the "Transmission Job", well OK, a complete Stroked Overhaul - Page 6 - JeepForum.com
post #76 of 188 Old 12-04-2012, 07:34 AM Thread Starter
W_A_Watson_II
No, I've not fallen off the face of the earth, I've been busy with Deer Season, Thanks Giving, Family and a few other things going on and have not had much time to work on the Jeep lately. I did get in a little work on the tub though. Finished the passenger side lower door support repair, and worked on the fuel pump access panel some more. Looks like my original plan of driving by Christmas is out the window, oh well, all is good though.
My "Transmission Job" & Stroker Build (My WEB Site)
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is offline
post #77 of 188 Old 12-10-2012, 09:42 PM Thread Starter
W_A_Watson_II
Back to doing a little work on the Jeep. I made a reinforcement to install inside the rear tub body cross member to mount the CJ tail gate to. I was able to slide it in and through the rust hole on the passengers side before doing it's repair. I also reinforced/repaired the right rear tub mount and started closing off the rust hole.
My "Transmission Job" & Stroker Build (JeepForum)
Will
Will Watson
post #78 of 188 Old 12-10-2012, 09:53 PM
Hard_oNe
Im learning from your progress no matter the size. Makes me want to take a class in welding.
Sent from my mobile thingy using the JeepForum thingy.
1989 Jeep YJ - "go slow"
2007 Trailblazer SS (6.0 LS2) - "go fast"
Hard_oNe is offline
post #79 of 188 Old 12-16-2012, 10:16 AM Thread Starter
W_A_Watson_II
Started the exterior rear corner repair. Finally used my body panel clamps to hold the patch panels in place while I spot welded them in. They work pretty good, but my thin sheet metal welding skills aren't the best. I will need to finish welding them from the back/bottom side, but before I flip the tub, I spot welded in the final fuel pump cover side flanges. After a little more welding and some body filler the tub exterior is getting closer to sanding and painting.
Will
Will Watson
post #80 of 188 Old 12-16-2012, 05:25 PM
TSEJEEPERS
Looking good Will!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #81 of 188 Old 12-16-2012, 06:22 PM Thread Starter
W_A_Watson_II
Thanks Tom.
I finished attaching and welding the Fuel Pump Access Cover. Also welded the bottom side of the rear tub mount reinforcements I made.
Will
Will Watson
post #82 of 188 Old 12-17-2012, 04:34 PM Thread Starter
W_A_Watson_II
Finished the bottom side welding, and patching a few more places that I found. Next to remove some broken dash bolts, lower door hinges, and the brake pedal assemble to start prepping for paint, etc...
Will
Will Watson
post #83 of 188 Old 12-19-2012, 06:56 PM Thread Starter
W_A_Watson_II
Well, let me tell you, cleaning out the old carpet glue was no easy task. The glue is almost all gone now, and I've de-greased the inside of the tub and the engine side of the firewall as well. I've done the same trim/opening of the rear wheel wheels that I did to my brothers Jeep. This will allow easily up to 35" tires with out further trimming, so my current 31" might look a little out of place. I also fabricated the tailgate latch brackets from some 1/2" tubing and adding a weld to snap the latches against. The only metal work left on the tub is to fabricate/attach the tailgate straps. then I can prime, and fill the body spots in preparation for paint.
Will
Will Watson
post #84 of 188 Old 12-20-2012, 10:22 PM Thread Starter
W_A_Watson_II
This afternoon a little more cleaning, and then some bare metal priming. I also removed the glass out of the replacement windshield frame and getting it ready.
Will
Will Watson
post #85 of 188 Old 12-21-2012, 04:02 PM Thread Starter
W_A_Watson_II
I started the Filling and Sanding today, and should have it done tomorrow. Then to fab a couple of tailgate strap attachment plates (still need some dimensions though) and weld in the tub side plates.
Will
Will Watson
post #86 of 188 Old 12-22-2012, 09:28 PM Thread Starter
W_A_Watson_II
Spent a little time fabricating the tailgate cable brackets and attaching them. Need to finish welding them on and cleaning the welds and priming, but the work as planned. I also finished the body filler and first tub sanding. Next is to apply the fill primer and finish the sanding in preparation for paint.
Will
Will Watson
post #87 of 188 Old 12-23-2012, 05:33 PM Thread Starter
W_A_Watson_II
Well, the Tub is sanded and almost read for paint. A couple of spots that needed a little more filling to be sanded and I still need to sand the firewall. Then the bottom can be re-undercoated and the tub can be painted.
Will
Will Watson
post #88 of 188 Old 12-26-2012, 08:14 PM Thread Starter
W_A_Watson_II
The Tub is done and loaded for the trip to the Paint Booth when it's available. I've also got the Hood, Windshield and Tailgate sanded and ready for paint as well. Next comes the grill shell.
Will
Will Watson
post #89 of 188 Old 12-26-2012, 11:14 PM
lucdog
1980 CJ5
What color Will? Looking good!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #90 of 188 Old 12-27-2012, 06:43 AM Thread Starter
W_A_Watson_II
Thanks Bill, I'm going Sahara Tan (2011-12 Jeep Wrangler Color). Figured it might look better in the long run in Tan than my original plan of Hemi Orange.
Will Watson
Do I "have" to drop the transmission skidplate to change mount? 26679cj5 TJ Wrangler Technical Forum 7 02-02-2012 09:16 PM
Are NV231's "one size fits all" or vehicle or transmission specific? skydiver30960 TJ Wrangler Technical Forum 3 07-01-2011 01:00 PM
Monster Transmission rebuild kits "parts Missing" jeffrey919r1 YJ Wrangler Technical Forum 1 01-13-2010 10:59 AM
"Stock" 32rh transmission flooded can't find breather vent CWBRider90 TJ Wrangler Technical Forum 7 01-07-2010 08:31 PM
Just started the "I go or the Jeep goes" fight johnroot01 Wrangler General Discussion 103 09-21-2009 06:56 AM
