Started the "Transmission Job", well OK, a complete Stroked Overhaul - Page 5 - JeepForum.com
post #61 of 188 Old 10-30-2012, 01:05 PM
TSEJEEPERS
Will how did you manage to get a picture of Bill without a cigar in his hand or mouth?
When you change the plugs, if it is still missing, make sure you check out the distributer. As our discussion at Steve's place, my 93 uses a 94/95 distributer and would sometimes run fine on the 93 distributer and other times not.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #62 of 188 Old 10-30-2012, 02:20 PM
lucdog
lucdog's Avatar
1980 CJ5
3 words, gasoline and ether!!
And thanks for letting me hang out. Two sets of eyes, and two people thinking , made for a good startup.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #63 of 188 Old 10-30-2012, 04:48 PM Thread Starter
W_A_Watson_II
Thanks ThomasYJ!
Tom, well I guess bill said it, he didn't want to loose what hair he had left, so he put the cigar out early on. I'll keep that in mind on the distributor. I'm thinking it was the plugs, but more run time will tell for sure. I didn't run it as long today after the plug and oil chnage but she seems to run a little rich.
Bill, any time, your help was greatly appreciated as indeed both of us going through everything using each other as a sounding board sure helped and made the non initial start less frustrating on my part. You have got to appreciate a guy who spends more time on the road than he got to spend here helping me, Bill it was greatly appreciated.
Will have more pix and info later, but man does this engine sound strong and sweet. Can't wait to get the body work done and it back on the road.
Will
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is online now
post #64 of 188 Old 10-30-2012, 07:30 PM Thread Starter
W_A_Watson_II
Well after yesterdays engine start and cam break-in, it was time to change the oil and install the new Spark Plugs. I elected to do the break-in with the old plugs figuring there might me some oil or other burn off that I didn't want to harm the new plugs. Not sure it was a wise idea, but I did it. As you can see in the first picture, Cylinders 3 & 4 (and partially #6) either weren't cleaned enough, or have problems and likely caused the miss the engine developed during the break-in. In the second picture you can see the cooler heat range NGK BKR6E-11 (RC9YC4) Spark plug next to one of the old Champion 4412's. (RC12LYC). While I had the plugs out I also did a room temp wet engine compression test. The results are as follows:
1 - 183 psi
2 - 182 psi
3 - 186 psi
4 - 183 psi
5 - 185 psi
6 - 183 psi
All in all only a 4 psi delta, and what I believe to be good numbers for a 9'ish Compression Ration Engine. I also checked (once I knew you could and how) checked for any Engine codes, and only found batter disconnect code which was expected. I changed the engine oil and filter and added the ZDD Plus Oil Additive. I rechecked the manifold torques, and noticed two of the exhaust pipes had a sign of what looked like oil run oil of the pipe to flange area. It's probably from the small oil leak that developed on the valve cover while running during the break-in. While the engine was running (break-in) I re-torqued the valve cover and believe I have the oil leak stopped. I also removed and extended the exhaust pipe to get the muffler to clear the skid plate, and further investigated the stock tail pipe position. I'll probably take it back, and end up having one made that fits better and is 2.5", not 2.25" in diameter. Now with the gas tank straps that arrived this afternoon, I can paint and install them and have the chassis done with the exception of drive shafts. I can't wait to get the body work done so I can see how well the engine performs. It sure sounds and runs sweet!
My "Transmission Job" & Stroker Build (JeepForum)
My "Transmission Job" & Stroker Build (My WEB Site)
Will
Will Watson
post #65 of 188 Old 10-31-2012, 07:03 AM
caoboy
Any reason you chose NGK's for your plugs? I prefer them, but was told in Jeeps they like Champion/Autolite plugs? I've used NGK's in everything else I've owned, but they were Toyotas and Hondas.
caoboy is offline
post #66 of 188 Old 10-31-2012, 07:34 AM
40FiveSeventy
Great thread, Will. Definitely watching this one for tips...you know, when I have an idea as to what I'm talking about and/or reading.
-The Mad Cap.
~*4FS.
40FiveSeventy is offline
post #67 of 188 Old 10-31-2012, 07:51 AM Thread Starter
W_A_Watson_II
caoboy,
I went in to O'Reilly's looking to get the Champion RC9YC4's, but they only had the NGK's in stock. One other Stroker poster on the stroker site was using them, so I figured it was a safe buy. However when I noticed the difference in tip length I was concerned, but it looks like the RC9YC4's would be the short tip as well.
Thanks 40FiveSeventy, hopefully others will learn from my mistakes.
Will
Will Watson
post #68 of 188 Old 10-31-2012, 08:28 AM
caoboy
Ahh ok. Thanks for the info.
caoboy is offline
post #69 of 188 Old 11-01-2012, 05:28 PM Thread Starter
W_A_Watson_II
Took advantage of probably one of the last nice days to wash off the weekends mud off the M37, and roll out the YJ to start and run the engine again. The intent was to let the engine run a good 30 minutes and see if the miss returned, and after almost 50 minutes, it did not. The engine still runs and sounds strong, but when you rev it the Air/fuel ration jumps around it it blows out some smoke. It still smells rich, but the A/F ration says different. Fluid levels are all holding steady and looking clean.
VIDEO - About 30-35 minuets into this run
VIDEO - About 45 minuets into this run
Will
Will Watson
post #70 of 188 Old 11-01-2012, 08:04 PM
rd94yj
Thia is an amazing thread! You have some dedication!
Congrats on a VERY clean YJ!
Subscribed.
rd94yj is offline
post #71 of 188 Old 11-02-2012, 09:39 PM Thread Starter
W_A_Watson_II
Started the Body work today, and started off with the driver side floor, as it was the biggest hole in the body. I picked up a cheap patch panel and cut out the the rusted floor material and the rust at the body side as well. I've cut the patch panel down to fit and cleaned the floor. Not to start welding in the patches.
Will
Will Watson
post #72 of 188 Old 11-03-2012, 07:02 PM Thread Starter
W_A_Watson_II
Spent some time this afternoon, cleaning out the tub, and applying some weld thru primer to the drivers floor. Next I started pulling off the tub interior items, rails, seat mounts, wiring, heating system, etc... As you can also see I have it on a set of wheels for easy movement and better side access.
Will
Will Watson
post #73 of 188 Old 11-04-2012, 05:03 PM Thread Starter
W_A_Watson_II
Welded in the floor and door support patches. Now to patch the outer body panel, and then move to the rear of the tub for those patches.
Will
Will Watson
post #74 of 188 Old 11-06-2012, 01:53 PM Thread Starter
W_A_Watson_II
Just a little work. I fabricated and welded in the outer panel patch for the drivers side door support area. Welding on this thin sheet metal just isn't my thing. I also removed the cracked/broken and cleaned up the cowl areas.
Will
Will Watson
post #75 of 188 Old 11-07-2012, 12:04 PM
hickatron
looking good, and I still think that looks less painful the the tranny we did in my exploder.
hickatron is offline
Do I "have" to drop the transmission skidplate to change mount? 26679cj5 TJ Wrangler Technical Forum 7 02-02-2012 08:16 PM
Are NV231's "one size fits all" or vehicle or transmission specific? skydiver30960 TJ Wrangler Technical Forum 3 07-01-2011 12:00 PM
Monster Transmission rebuild kits "parts Missing" jeffrey919r1 YJ Wrangler Technical Forum 1 01-13-2010 09:59 AM
"Stock" 32rh transmission flooded can't find breather vent CWBRider90 TJ Wrangler Technical Forum 7 01-07-2010 07:31 PM
Just started the "I go or the Jeep goes" fight johnroot01 Wrangler General Discussion 103 09-21-2009 05:56 AM
