Quantcast Started Herculiner project - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Started Herculiner project
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 04-21-2007, 03:38 PM   #1
blackmax
Started Herculiner project...........what do you think?
blackmax is offline   Reply With Quote
Old 04-21-2007, 03:57 PM   #2
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
click free
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Old 04-21-2007, 05:05 PM   #3
MN_Sasquatch
what did you use to prep it?
looks good
MN_Sasquatch is offline   Reply With Quote
Old 04-21-2007, 05:10 PM   #4
blackmax
looks good
I used a rust resistant, non glossy Krylon paint. Hopefully, after much reading on this site, that will help to adhere to body even better than just to metal. I will wipe down with acetone to make sure I have good bond first. Will start herculining Tues or Wed...........wish me luck
Old 04-21-2007, 06:59 PM   #5
MN_Sasquatch
what i ment to ask was what did you use to prep for the paint you put on, grinder, what kind, grit, how did it pan out?
Old 04-21-2007, 08:16 PM   #6
blackmax
I used 40 and 80 grit sandpaper. It was very slow due to the old liner. So I then went to a propane torch to heat original liner and a putty knive to scrape. That was definitely the ticket. After removing or at least smearing old liner, I took drill with wire brush and removed most everything else.
The sanding is a lot of work. Once I went to the torch and the steel brush, things moved much faster!!
If I didn't want to take it to the metal, I would just use sand paper and kind of rough up the paint. If I wanted to take it all the way to the metal before Herculining, I would definitely use wire brush....... get rid of any rust and prep with a rust resistant paint.
What ever you do, don't get any on your Hootus!!!
Old 04-21-2007, 09:46 PM   #7
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
That never gets old does it. Looks good man.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 04-21-2007, 09:58 PM   #8
Coolhand1
I finished My Hurculiner yesterday, best move I have made with my YJ. I used the Grey kit and it took exactly 1 gallon. I found the more you schlep it on the better it looks.
Coolhand1 is offline   Reply With Quote
Old 04-22-2007, 02:43 PM   #9
blackmax
Looks great!! Did you use a gun? if so where in the h*ll did you find one that would work good?
Old 04-22-2007, 03:01 PM   #10
Coolhand1
No Gun, just the rollers and 2 1 1/2 brushes, "dabbed" with the brushes. Tried to "paint" with the brushes and the rubber balled up so I started dabbing and "schlepping" and it worked great! just don't try to be Rembrandt.
Old 04-22-2007, 03:28 PM   #11
NewdRiver_
Saw your Jeep in the profile. I like those rims. What are they?
NewdRiver_ is offline   Reply With Quote
Old 04-22-2007, 03:45 PM   #12
jmhat98
Looks good
jmhat98 is offline   Reply With Quote
Old 04-23-2007, 07:30 PM   #13
Kush69
Looks great so far. I just did mine this weekend( what a pain in the a** ). Be patient..
Kush69 is offline   Reply With Quote
Old 04-23-2007, 07:39 PM   #14
BigMikey
I did mine this weekend too. Prepping was a pain in the *** but it was beautiful weather so i didnt really mind. Prepping took me probably 7-8 hours of sanding, wire brushing, and cleaning the surface. Needless to say my Herc looks pretty sweet
BigMikey is offline   Reply With Quote
Old 04-23-2007, 09:04 PM   #15
blackmax
Originally Posted by Big-n-Broke-YJ
click free
Sorry, I put in bad links. I'll try again later
Glock Forum
