Start Probs.. - Page 2 - JeepForum.com
post #16 of 23 Old 09-01-2013, 06:00 PM
bigbossd1030
That's great news! Glad I could help. You should have codes 12,33 and 55. If you have any other codes. Fix as needed. Your o2 code shouldn't be there unless its got a problem.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #17 of 23 Old 09-01-2013, 07:36 PM
Que89YJ
You can check codes yourself:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Disconnecting the battery clears all the codes except the normal 12,33,55
Que89YJ is offline
post #18 of 23 Old 09-01-2013, 10:12 PM
Maineshootah
Originally Posted by caseybam1128 View Post
Thank you so much bigbossd, my Wrangler lives again! When I first got her goin she was idling pretty rough and the check engine light is on but now it smoothed out. Check engine light is still on, but the guy at autozone read the codes, gave me the a/c relay, battery recently disconnected, and something with an O2 sensor, but it's most likely the battery which will go away after 10 starts or so. Again thank you so so much, saved me tons of money
awesome!
Another certified brain sergeon in our mix! congrats on the repair.
I guess my YJ Is my midlife crisis therapy.....
My 95 YJ cross country (AZ to ME) frame swap thread.
http://www.jeepforum.com/forum/f22/maineshootahs-cross-country-95-yj-build-1487587/
Maineshootah is offline
post #19 of 23 Old 09-01-2013, 11:07 PM Thread Starter
caseybam1128
Originally Posted by Maineshootah View Post
awesome!
Thanks Maineshootah! proud to be one. And Que89YJ, Thanks I will check it out!
And bigbossd, again I can't thank you enough. If it wasn't for you I would still be driving my girlfriends cavalier
caseybam1128 is offline
post #20 of 23 Old 09-01-2013, 11:38 PM
bigbossd1030
Lol well thank god I was able to save you from that! I have a little cavalier in my jeep though. Those seats are not too bad. Cheap too. Any, congrats on the repair! Hope she keeps jeepin on for you!
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #21 of 23 Old 09-06-2013, 11:43 AM Thread Starter
caseybam1128
Thanks! codes seemed to stabilize, check engine light use to come on after driving some distance but doesn't anymore. Aside from the normal codes I was getting code 51 Oxygen Sensor - lean condition indicated
post #22 of 23 Old 09-06-2013, 12:07 PM
Que89YJ
51 lean is usually a leak in your exhaust or a bad O2 sensor. It usually is the exhaust manifold bolts loose or a cracked manifold at the collector tubes. You are dumping fuel if you have that faul and it does effect the way it runs. You need to check it out.
Que89YJ is offline
post #23 of 23 Old 09-06-2013, 12:37 PM
bigbossd1030
Yup, fix er up.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
