Start Probs.. - JeepForum.com
post #1 of 23 Old 08-29-2013, 07:07 PM Thread Starter
caseybam1128
Start Probs..
caseybam1128 is offline
post #2 of 23 Old 08-29-2013, 08:20 PM
youngjeepr
Do you have fuel at the fuel rail? Do you have spark? There is a way to test the computer but I'm not sure how... I'm sure someone that knows will chime in so you don't have to waste anymore money.
When did your problem start?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #3 of 23 Old 08-29-2013, 10:51 PM
bigbossd1030
When you turn the key to the on position. Does the cel come on? If it doesn't you need to search up brain surgery.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 23 Old 08-29-2013, 11:48 PM Thread Starter
caseybam1128
youngjeeper, I have yet to check fuel at the fuel rail, but I can hear it flowing into the engine (possibly flooding?) I will check that tomorrow. And mechanic said I wasn't getting spark, but can't exactly designate location because it won't start now. The problem started when me, my girlfriend, and my stubborn Jeep took a trip 420 miles away to visit family in Philadelphia. The problem started of very mild, as if the starter was the issue because it would just take the starter a few more cranks than usual to get going. This was about a month ago when it all began.
bigbossd1030, what do you mean by cel?
post #5 of 23 Old 08-30-2013, 01:13 AM
youngjeepr
See if your getting power to your coil while cranking if you are and your plugs arnt sparking its a bad coil. If you don't have power to your coil it's either a wiring problem or your ecm
post #6 of 23 Old 08-30-2013, 01:14 AM
youngjeepr
I just read that you replaced your coil so it's most likely a wiring or ECM problem assuming you have fuel and NO spark
post #7 of 23 Old 08-30-2013, 07:11 AM
bigbossd1030
Check engine light. It should light up when you turn the key to the on position.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #8 of 23 Old 08-30-2013, 12:14 PM Thread Starter
caseybam1128
Youngjeepr, I'm assuming the same, but computers are expensive and idk if that's for sure my problem /:
And bigbossd, my check engine light doesn't come on in the run position since this problem started. Only the seatbelt light. And also I think it may be important to note that I drove it to work a week ago, after my shift took me about 20 min. To get it to roughly start. When it started all my dash lights just went out an the lights aren't working. Also it died on me while driving on the highway only once the same night on my way home. Took another 10 min to start
post #9 of 23 Old 08-30-2013, 02:18 PM
youngjeepr
I'm not saying by a ECM yet I would test it before you replace it... Search on the forum and I'm sure something will come up on how to test it.
post #10 of 23 Old 08-30-2013, 03:23 PM
bigbossd1030
You don't have to replace the ECM. You need to replace the capacitors in it. Search up brain surgery on how to. It's as simple as soldering in three new capacitors into the computer.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #11 of 23 Old 08-30-2013, 04:38 PM Thread Starter
caseybam1128
Big bossd, I looked up a write up on brain surgury and looks fairly easy, I'm going to give it a shot! Have u tried doing brain surgery before?
post #12 of 23 Old 08-30-2013, 05:21 PM
bigbossd1030
I haven't personally. But I have read the writeups for when I have to. If you can run a soldering gun. Then you shouldn't have a problem. Just do exactly as the writeup says.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #13 of 23 Old 08-31-2013, 01:03 PM Thread Starter
caseybam1128
Alright I got all the parts today so will try to perform the brain surgery tonight! I will let u know of it works for me tomorrow. Keeping my fingers crossed!!
post #14 of 23 Old 08-31-2013, 02:23 PM
bigbossd1030
Us as well. Good luck!
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #15 of 23 Old 09-01-2013, 01:39 PM Thread Starter
caseybam1128
