Star like seal in xcase? - JeepForum.com
post #1 of 12 Old 01-14-2014, 06:32 PM Thread Starter
bigbossd1030
I got my yoke in the mail today and after we pulled the ole one out we found this star/spiky rubber piece, I have a new one from a kit from a while ago, but this one is all mangled. Is this normal???!!!! Should I be concerned?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #2 of 12 Old 01-14-2014, 06:36 PM
kloppk
It should look like the one on the left.
Someone probably didn't have the one on the right properly seated before they tightened the nut.
It's purpose is to seal between the yoke and the output shaft.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 12 Old 01-14-2014, 06:38 PM Thread Starter
bigbossd1030
Originally Posted by kloppk
It should look like the one on the left. Someone probably didn't have the one on the right properly seated before they tightened the nut.
do you know how to seat it properly? Is it just as simple as making sure it's flat and in the splines?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #4 of 12 Old 01-14-2014, 06:38 PM
kloppk
Yes - in the splines of the yoke
Baystate Jeepers
Deep Woods Extreme
kloppk is offline
post #5 of 12 Old 01-14-2014, 06:46 PM Thread Starter
bigbossd1030
does the seal go first? Or after? I don't want to mess this up.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #6 of 12 Old 01-14-2014, 07:00 PM
kloppk
Slide the yoke onto the shaft all the way.
Install the star seal onto the shaft and carefully line up the tips of the seal with the teeth in the yoke.
Carefully press the star washer into the all of the teeth in the yoke. It should be lying flat and just about flush with the surface the yoke nut presses on when it's tightened.
Install the nut and torque to spec.
As the nut tightens the last bit it compresses the star washer causing it to expand and seal.
Baystate Jeepers
Deep Woods Extreme
kloppk is offline
post #7 of 12 Old 01-14-2014, 07:19 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
None of those are intact once they leave the factory. Every one that I have opened up has been mangled beyond recognition. I have even used rtv in lieu of one once. Its still going strong in a friends TJ.
Luck Favours The Prepared
Anticanman is offline
post #8 of 12 Old 01-14-2014, 08:06 PM Thread Starter
bigbossd1030
Thanks guys, got it done and no leak so far. Haven't tested it yet, found a crack around one of my skid plate bolts so I'm going to fix that at work tomorrow. Might think about a new plate soon. Thanks again.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #9 of 12 Old 01-15-2014, 08:02 AM
gunshw301
Can I get a confirmation? I was always told that the rubber washer was placed opposite of the splines......so the peaks and valleys of the washer would not match up to the peaks and valleys of the shaft.
I have done this on a few tc rebuilds with no leaks that I have noticed. Maybe it does not matter?
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #10 of 12 Old 01-15-2014, 08:24 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It only fits snugly one way and kind of falls into place once you poke and prod.
post #11 of 12 Old 01-15-2014, 10:24 AM Thread Starter
bigbossd1030
I placed the star seal to match the splines. It seamed to slightly sit above flush. If it sat opposite of the splines.... Why would it even have the points? Why not just a circle if you are going to mash the seal up anyway? I don't know, I just put it inside the splines and ill test it out tonight after I put the skid back on to see if it leaks or not.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #12 of 12 Old 01-15-2014, 10:30 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It should sit above flush and then when the nut is torqued, it'll smash in every little crevice and put pressure on every side that it touches which is a lot considering the points. If you end up with a leak, the star isn't seated or the outer seal is out.
