Standing water in cab - JeepForum.com
post #1 of 15 Old 03-09-2009, 12:30 PM Thread Starter
ticconi
Ok so it rained pretty hard last night got in the jeep today and noticed standing water in the backseat where the backseat passengers would put their feet. Seats and everything else was dry anyone have any idea of whats going on here? thanks in advance!
ticconi is offline
post #2 of 15 Old 03-09-2009, 12:37 PM
Douglas S.
Just pull the floor plugs and let it drain out.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #3 of 15 Old 03-09-2009, 12:41 PM
jimaug87
if you still have carpet (hey! it's possible), you'll have to pull that back. I cut out holes in the carpet up front to let the water drain better.
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline
post #4 of 15 Old 03-09-2009, 12:55 PM
cmsurfer
I used to have a Bestop Sunrinder top. The windows never really sealed to the Jeep too well and I would have some water end up back there...
cmsurfer is offline
post #5 of 15 Old 03-09-2009, 01:05 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
did YJ's come with carpet? I have never seen with that still had it.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #6 of 15 Old 03-09-2009, 01:11 PM
SHJeeper
They do come with carpet, mine did, can't really take it out though. Same reason as why I don't have to worry about pulling the plugs, It's just one big hole under the carpet, and the carpet is all the lets me put my feet down.
SHJeeper is offline
post #7 of 15 Old 03-09-2009, 01:12 PM
cmsurfer
Yes sir... Still have mine mostly intact
cmsurfer is offline
post #8 of 15 Old 03-09-2009, 01:32 PM
Douglas S.
Mine had carpet, but it is no more. Well, it's in my garage, but it's never going back in.
post #9 of 15 Old 03-09-2009, 01:43 PM Thread Starter
ticconi
yeah i still have carpet and it's in perfect shape too. Well except for the standing water in the back lol ok i guess ill just have to do this every time it rains hard then oh well another quirk of the jeep!!
ticconi is offline
post #10 of 15 Old 03-09-2009, 01:54 PM
SHJeeper
If I were you.... the way I found out where my last leak was, take it to the car wash, dump a couple quarters in and spray the thing down (perferably after you drain the other water). Spray at every point where the jeep and the top meet as well as the entire top, and spray it good, once done take a look around the inside and see if you can find out where the water came in from. See if you can find it that way...
SHJeeper is offline
post #11 of 15 Old 03-09-2009, 02:39 PM
WranglerRush
I have sat in mine while it was raining to see exactly where it is leaking. Take the carpet and the plugs out and let it drain, clean it, and herculine it. I love my herculiner.
1992 Red YJ 4.0 with 5 on the floor and 33's
WranglerRush is offline
post #12 of 15 Old 03-09-2009, 04:54 PM
95 Lowbuck
Right under the windshield their is a grate for an air intake.
The box underneath that drains out the firewall through a big rubber tube.
When it gets clogged up, water winds up in the foot wells
95 Lowbuck is offline
post #13 of 15 Old 03-09-2009, 08:05 PM Thread Starter
ticconi
water is in the rear footwells. we are supposed to get a butt load of more rain so i am just gonna sit in it and see where it comes in. Thanks for the helps guys
ticconi is offline
post #14 of 15 Old 03-09-2009, 08:22 PM
buckshot500
X2 on this!!!
Under the hood, just inboard of the battery you will see a large (2") vertical rubber tube.
On an I-6, it's right above the starter motor. That tube is the drain for the cowl vent. The lowest point of this tube is kind of pinched. It clogs up with leaves & needs to be cleaned out, all the way. I use a garden hose after removing the cowl vent grille.
Have a helper hold the pinched end open, so all the junk can be rinsed out.
buckshot500 is offline
post #15 of 15 Old 03-10-2009, 05:15 PM Thread Starter
ticconi
Originally Posted by buckshot500 View Post
X2 on this!!!
but the water is collecting in the rear footwells not the front, this wouldn't cause that would it?
ticconi is offline
How to use your CO2 tank laying down or standing up. LSU_TJ TJ Wrangler Technical Forum 15 11-18-2010 07:55 PM
standing on the freedom top nhjku JK Wrangler Technical Forum 6 02-10-2010 01:19 PM
Should standing water seep through new Replace-A-Top? livinthedream Wrangler General Discussion 3 11-21-2009 08:51 PM
Standing Water after a storm kellerumps TJ Wrangler Technical Forum 20 08-10-2009 09:03 AM
Standing water under dash. jeepchick20 TJ Wrangler Technical Forum 3 08-19-2005 09:16 PM
