standard Water pump or High Flow - JeepForum.com
post #1 of 4 Old 09-19-2001, 07:15 AM Thread Starter
OhYeah
Hey friends,
I was looking on 4wd hardware's sight and they have 2 different water pumps for my wrangler. One is what looks like a standard pump for $56 and the other is a high flow for $109. Is there anything great I can expect from the high flow? I have a 91YJ 4 cyl. as you can see in my sig. Is it worth the extra $50 to get the high flow?
Thanks,
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #2 of 4 Old 09-19-2001, 08:01 AM
JeeperJay
IMHO I'd say no. I just replaced mine with a standard pump for $35 at my local auto parts store and I have no problems with it. Unless you're running huge tires with the wrong gears you shouldn't have any cooling problems with the stock cooling system.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #3 of 4 Old 09-19-2001, 08:13 AM Thread Starter
OhYeah
Hey,
Currently I am running 31x10.5 but I am going to be going with a 33x12.50 soon. Currently I also have the stock 4.10 gears. Someday I will probably upgrade to 4.56 at the same time I do my engine swap and I hit the lotto. So will I be OK with the standard pump? Are there any differences between one I find at 4wd hardware's site and one from Autozone?
Thanks,
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #4 of 4 Old 09-19-2001, 08:52 AM
JeeperJay
I can't say for sure if there is any difference. But I can't imagine there would be much difference. I don't think there are many mods that could be done to a water pump. They are pretty basic. High flow pumps have more impeller blades which gives you better flow while using less power to do so. They also make different pump casings such as cast iron for durability or aluminum for light weight. The stock pump in your jeep should be a aluminum casing. Pumps with better quality bearings will also increase your flow/horsepower use. If you're looking at a more expensive pump, get all the info you can about it first to make sure you're not getting ripped off. Hope I've been some help.
high flow water pump question MC_NickP TJ Wrangler Technical Forum 0 03-17-2009 08:00 AM
Quadratec Flowcool high flow water pump MAILEBOY YJ Wrangler Technical Forum 0 01-05-2009 01:58 AM
reverse rotation water pump and hi-flow ?? jbolty YJ Wrangler Technical Forum 5 08-03-2007 02:44 PM
2 row or 3 row radiator, & high flow pump Fargo TJ Wrangler Technical Forum 15 07-24-2006 07:58 PM
High Flow water pump bucko81 YJ Wrangler Technical Forum 10 11-13-2003 11:24 AM
