Standard Transmission for 87 Jeep Wrangler V-6 (258) - JeepForum.com
post #1 of 9 Old 01-12-2009, 01:04 PM Thread Starter
TBS1970
1987 YJ Wrangler
Hello Board,
I am newbie and just bought my 16 year old son a one-owner 1987 Jeep Wrangler Sport with 88k miles (45k on engine) for his Christmas gift. I have already put in a Sachs clutch kit, warrior gas tank skid plate, and am now being told I need either(both) a new transfer case or transmission. The problem is whenever I shift into reverse and let the clutch out I hear a pretty loud "thumping" or clanging as the Jeep backs up. At first, I thought it was the U-joint but that was not the case. A local garage told me it is either the chain in the transfer case or the tranny is bad with a price tag of between $750-$1000. Any advice or suggestions on what it is maybe or what to do? Where can I find a decent used transfer case and/or tranny?
Thanks!
Tom
TBS1970 is offline
post #2 of 9 Old 01-12-2009, 01:11 PM
befumo
i6, AMC 258**
befumo is offline
post #3 of 9 Old 01-12-2009, 01:33 PM
TheNewbie
I wouldn't pay for a rebuild on the tranny. The rebuilt transmissions tend to need to be rebuilt over and over. I would just go to a local salvage yard and get another low mileage replacement.
TheNewbie is offline
post #4 of 9 Old 01-12-2009, 01:39 PM
flame0086
Originally Posted by befumo View Post
i6, AMC 258**
That doesn't help out his situation.
I dought its the transfer case chain. If it were, I'd imagine that it you would hear in every gear. This makes me think its the tranny.
Unfortunately, the 87 came with a Pugout tranny, which is known for not beeing a good tranny. I think 89 is the year they switched to the ax15. People have switched to the ax15 before, and a little bit of research should shed some light on the situation. If your son replaced the clutch himself, then he can swap in a different tranny himself and save you a lot of money. When I was looking for a new tranny I was finding them for $600.
car-part.com is a good place to look
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #5 of 9 Old 01-12-2009, 01:52 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
I'd bet tranny also. The transfer case would grenade pretty fast if it was the chain.
On the Peugeot, it is weaker and prone to failure. Also unless it's free, not worth the rebuild.
If you can swap a clutch, you can install an AX-15.
Total is about 600 bucks. Read through here..
http://www.jeepforum.com/forum/f19/yj-trans-swap-ba-10-5-ax-15-write-up-312203/
- Ernie
Richmond88yj is offline
post #6 of 9 Old 01-12-2009, 02:07 PM
jeepian
Look for a ax 15
88 YJ/ 4" suspension lift / 2" BL / 35s procomp xmt / 44/8.8 w 4.56
jeepian is offline
post #7 of 9 Old 01-12-2009, 02:12 PM
kloppk
Does it only make the noise in 4WD when backing up or does it also do it in 2WD?
BTW if it's a stock Jeep it will have the Peugeot BA/10 tranny and the oddball NP207.
The NP207 was only used in the 1987 YJ's. They switch to the better NP231 in 1988 and beyond.
The Peugeot BA/10 was only used in teh 6 cyls from 1987 thru March of 1989.
after that Jeep switched to the superior AX-15 tranny.
If it turns out it's the tranny I'd recommend you seriously consider not dumping any money into the tranny but to swap out the exsiting NP207 Peugeot BA/10 combo and replace it with an AX-15 and Np231 setup out of a slightly newer YJ.
Suggestions for places to find parts...
- Craigslist
- www.car-part.com
- Local Jeep forums
- Local junk yards
I have a "parts" Peugeot tranny in my shed. If you tear into the tranny and find a broken part let me know
I'd be happy to ship you the part(s) (if I have it) for the price of shipping.
kloppk is offline
post #8 of 9 Old 01-12-2009, 04:05 PM Thread Starter
TBS1970
1987 YJ Wrangler
Thank you!
Hello Board,
I really do appreciate all of the advice I got! I also thought it would be the tranny and not transfer case. I may run her until she dies and then upgrade to the A-15 per the many recommendations I got. It looks like the 16 year old better start working more hours!
Tom
TBS1970 is offline
post #9 of 9 Old 01-12-2009, 04:23 PM
veritas4156
1991 MJ Comanche
Here's an awesome site to check for parts in junkyards near you: http://www.car-part.com/ Thats where I found a junkyard that had a motor for my jeep for 300 bucks delivered!
veritas4156 is offline
Standard Transmission to an Automatic jkoch8819 YJ Wrangler Technical Forum 15 10-23-2009 10:27 AM
ATF in standard transmission? ZeroGravity YJ Wrangler Technical Forum 14 09-12-2009 05:25 PM
HELP, transmission swap, standard to an auto. Is it a pain? Blue84JeepCJ7 TJ Wrangler Technical Forum 8 08-07-2009 10:41 PM
Transmission Problems???Jeep TJ Wrangler 05 ldenis TJ Wrangler Technical Forum 11 07-08-2008 12:08 AM
changing fluid on standard transmission heep98 TJ Wrangler Technical Forum 8 11-13-2002 08:23 PM
